| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Remove Old Door Trim Inside a Front Door
by eHow.com
When installing a new door, don't forget the trim. You want the style of door to match the style of trim, not clash, so that the money you invested in a new door will be worthwhile. The good news is that it's a lot easier to replace the door trim than to... Read More » Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
How to Measure & Cut Door Weather Stripping
by Expert Village
We’ve gotten all the area all prepped around the door to install the new weatherstripping. What you want to do is close your door and then you’re going to measure it. And just make sure that you measure all the way down to the corner. Measure... Read More » In this clip, we're going to be replacing a tailgate and I'm going to be picking out the tools and de-trimming the door panel for the new gate to go on. When removing a trim panel, the easiest tool to use is a door trim panel tool. It's always a good... Read More » Now I'm re-installing the cover on the inside of the gate. Now I'm replacing some of the trim panel clips because they were damaged and not functioning. Now I'm installing the interior trim panel. You just line up the holes with the fasteners and lightly... Read More »
