Exterior Door Install - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 09:57 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
When nailing or screwing the door to the framing.
Would you put your fasteners through the latch and hinge portion of the jamb or the exterior side?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-25-2011, 10:43 AM   #2
DIY Enthusiast
I put them behind the weatherstripping and replaced several hinge screws with longer ones to reach the framing. In your words, the "latch and hinge" side.
Ed G is offline   Reply With Quote
Old 07-25-2011, 10:58 AM   #3
I do both nailing thru shims
The older I get the better I was
Old 07-25-2011, 11:13 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
I do also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-25-2011, 11:22 AM   #5
kwikfishron's Avatar
Rewards Points: 370
^^^^All of the above.^^^^
kwikfishron is online now   Reply With Quote
Old 07-25-2011, 11:49 AM   #6
I have gas!
Thanks all,
The instructions that came with my door only mentioned fasteners in the interior portion of the jamb. I thought that was odd as there's more meat on the exterior side. I'm planning on countersinking screws and plugging the holes.
