Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-04-2012, 09:54 PM   #16
Exterior door construction
good luck i was taught a long time ago to learn from other peoples mistakes and to learn from them by learning the most i can from as many resources possible but i guess that is not your train of thought.
i was not talking about the thickness but the width of a 1x6 for a cabinet door panel. it is not done to todays standards due to stability it is better to laminate many smaller 1x's together and the same goes for larger doors but you already know that by what i am reading
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
