Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-24-2010, 09:47 AM   #1
editor
Unhappy
Exterior Anderson French Doors
Hi all,
Two years ago I had Anderson French doors installed to go onto our deck. I just recently started having problems locking the doors. I have to pull and lift hard in order to lock the handle. The doors open and close well. It's just the locking that's a problem.
Any suggestions?
baclarks is offline   Reply With Quote
Old 01-24-2010, 09:51 AM   #2
sagging door, usually shows as uneven reveal at head jamb. a long screw thru top hinge will help to pull door back up. can you post pic
Old 01-24-2010, 09:55 AM   #3
editor
Smile
Thanks for the suggestion. I'll try to get pic of jamb and lock in a few.
Old 01-24-2010, 09:02 PM   #4
Cabinet maker
Augie Dog's Avatar
Anderson doors usually have adjustable hinges.
Get some literature about how to use them if the doors are in need of adjustment.
Augie Dog is offline   Reply With Quote
Old 01-25-2010, 07:43 AM   #5
Augie beat me to it. Andersen Frenchwood hinges are fully adjustable. Look on their website for instruction if your installer did not leave them for you. Long screws should not be the issue if the door was properly installed. Andersen supplies long screws with the door.
French doors help... macdc Building & Construction 3 01-24-2010 12:17 AM
Exterior french doors install? imola ghost Carpentry 3 11-16-2009 06:06 AM
Replacing Sliders with French Doors ElizaWhyza Remodeling 2 03-31-2009 11:26 PM
Installing french doors in a load bearing wall johnsan Building & Construction 6 01-03-2009 05:59 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
