Extension Jamb Too Wide On Prehung Entry Door, Can I Fix It? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 08:35 PM   #1
Angry
Extension jamb too wide on prehung entry door, can I fix it?
I bought an entry door at an auction with a 6 9/16" extension jamb. Non refundable, non returnable. Unfortunately, my house was framed with 2by4s, so the extension jamb is too wide for my existing door frame. We are in the middle of a major remodel- adding a second story and widening the entry where this door will go. Can the framer just reframe the entry door with 2 by 6s? Is there some other fix that would work? thx.
rdrews is offline   Reply With Quote
Old 03-22-2013, 08:44 PM   #2
Rewards Points: 14,294
Is the wall already up? If so how many studs are that the wall?
You can not just reframe around the door, the whole wall would have to be redone or the doors going to stick out of the wall.
Old 03-22-2013, 08:47 PM   #3
Rewards Points: 6,652
They could, and that would leave you with a 2" box sticking out into the entry, or just frame that section of the entry to be just 2x6, and make sure they frame the stud for the drywall to attach at that corner, to be where the 2x6 framing meets it.
I did the 2x4 framing for an entry door on a mobile home I had, and then just trimmed it out, so that I had a little shelf at the top, that I could place a key for the deadbolt on. I had a ex-wife that when I met her was pregnant by this loser, who had a son at that time, that was sever adhd, and would escape on us, if we would have just had a standard deadbolt with a thumb turn on it. Of course that is a story in itself, but in turn we had two great kids before we got divorced, and things are great for them, but not so great for their older brother who is in trouble with the law & courts.
Old 03-22-2013, 09:24 PM   #4
is the jamb extension metal or wood. if its wood just cut it down to fit the wall.
Old 03-22-2013, 10:08 PM   #5
The entry is only going to be 8' wide. So if the framer reframed the door with 2 by 6s and put some extra studs along the wall to attach the drywall to, would that work?
Old 03-22-2013, 10:14 PM   #6
Didn't I state that in post #2 as the way to make this work. Put up a drawing of your floor plan, showing walls, and the entrance.
Old 03-23-2013, 06:22 AM   #7
Just making sure I understood.
Old 03-23-2013, 06:25 AM   #8
Name:  Main floor.jpg
Old 03-23-2013, 07:55 AM   #9
kwikfishron's Avatar
Rewards Points: 998
There's no reason that I can see why that wall can't be furred out.
Why aren't the exterior walls 2x6 to begin with?
kwikfishron is online now   Reply With Quote
Old 03-23-2013, 08:02 AM   #10
It's a remodel not new constrution.
Old 03-23-2013, 08:44 AM   #11
Rewards Points: 44
You could have your contractor build a new frame for the door.
djlandkpl is offline   Reply With Quote
Old 03-23-2013, 02:13 PM   #12
Just have them reframe the opening with the 2x6 framing, and also put in a stud on the walls on the side, so you can rehang drywall. Plus side is, you can re pull the doorbell & lighting at the entrance, plus install Cat-5e or Cat-6 with coax in case you wish to place a video camera at the entrance, to allow you to check who is at the front door, without going downstairs, or coming back upstairs, or from your bedroom.
You are at a great opportunity right now with the remodeling, with being able to do a lot of stuff that needed to be done. Pulling Ethernet wiring & coax to locations that did not have it before, along with locating a/v equipment in an area such as a closet or downstairs, to allow whole house distribution, along with the front & back entrance cameras & mic's.
Old 03-23-2013, 05:42 PM   #13
Haverhill Trade 1965
That shouldn't be that many studs. If the wall is already framed and don't want to re do it you, or they could rip some 2" pieces from some 2x's and nail them to the face of every stud, jack, etc. A little construction adhesive would help. Add the corner nailers.
Duckweather is offline   Reply With Quote
Old 03-23-2013, 07:05 PM   #14
Rewards Points: 268
How about planing the frame down to the correct size for the wall?
packer_rich is offline   Reply With Quote
Old 03-23-2013, 07:23 PM   #15
Lord of Slums
Rewards Points: 1,974
what sort of door are we dealing with here. Sounds like the makings for a headache. Ask the framer if he is willing to install this door. Unless he is brain dead he could give you an answer in five minutes.
mj12 is offline   Reply With Quote
Tags
casing , extension jamb , exterior door , prehung
Jamb Extension? jgrohol Windows and Doors 10 04-08-2012 09:59 PM
Window Jamb Extension xlr8tn Carpentry 3 05-14-2011 12:32 PM
Oak casing to a vinyl jamb extension on a new window? Dustball Carpentry 13 04-14-2010 11:06 AM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 07:45 PM
6" wide door jamb opening?? floxy Carpentry 3 01-15-2008 08:54 PM
