Extending Cupboards From Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 09:35 AM   #1
Question
extending cupboards from wall
How can I build an extension to bring laundry room wall cabinets 6" from wall?
Tobias is offline   Reply With Quote
Old 04-11-2011, 12:19 PM   #2
Rewards Points: 5,336
Do you want to shift the cabinets you have off the wall by 6" or do you want to make them 6" deeper?
Ron
Old 04-11-2011, 01:51 PM   #3
Shift them away from the wall by 6"
Old 04-11-2011, 03:35 PM   #4
You can build a 2x6 frame that matches the cabinet size. Install blocking at both the back and front of the frame, top and bottom(so 4 blocks). You can use the 2x6 stock or 2x8 or 2x10 if you have any scrap. Screw(framing screws, not sheetrock screws) and use adhesive to attach the blocking to the frame on all 3 sides. After the frame is dried, bolt it to the wall every 16 " The number of bolts depends on the size of the frame. After the frame is on the wall, screw the cabinets to the frame.
The type of bolts depends on the foundation type.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Tobias (04-11-2011)
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 04:44 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 10:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
