Exposed Rafter Ceiling In Extension Bedroom - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 12:43 AM   #1
Rewards Points: 1,062
Question
exposed rafter ceiling in extension bedroom
i estimate that the extension to my house, which has the kitchen on the 1st floor and portion of a bedroom on the 2nd floor, was built some time in the 30s, judging by the materials used. it was definitely not built with the house in 1909, which is what makes it an extension.
i am renovating the upstairs part and was thinking about making the rafters exposed and wanted to see what you all think, whether it's a good idea or not. the section is about 10'x11' and the evenly spaced 6 rafters run along the 10' side. the gradient is not much, maybe 12 deg max. i was thinking to first apply some insulation between the rafters (foam panels) and then post some interesting-looking tongue-n-groove decorative 1x4,5, maybe 6 fancy looking interior lumber to make it look kind of like a sauna or some scandinavian log house.
so i was wondering if that's a good idea and whether it is doable, have no experience doing such a thing considering it involves increased moisture exposure cause it's the other side of the roof.
pictures attached (left and right side).
thanks
exposed rafter ceiling in extension bedroom-exposed_rafters_1_x.jpg   exposed rafter ceiling in extension bedroom-exposed_rafters_2_x.jpg
Old 11-23-2011, 06:34 AM   #2
Hmmmm, no repies............??? There are ways to insulate so there is no moisture issue with the roof sheathing, but I would consult a local expert. There certainly is not much space to get the result you seek and still have an insulated room. And those pics raise some questions regarding the contruction.
Old 11-23-2011, 02:24 PM   #3
Rewards Points: 1,766
Amareck: you dont' say where you live but insulating that space would likely be a challenge and have anything meaningful in the way of exposed rafters. Also have to consider ventilation of the roof sheathing. Hard to tell if your sheathing is wet in spots or just coloration? Personally, exposed 2x4s wouldn't be as visually interesting to me like a beefy 4 x6 or something.
bob22 is offline   Reply With Quote
Old 11-23-2011, 05:20 PM   #4
somewhere mid-Atlantic between SC and NY...
coloration
the 2x4s are from the old ceiling that i demolished. i wanna take them down and leave the rafters, which are 2x6 and could be refinished
thanks
Old 11-23-2011, 08:54 PM   #5
Msradell's Avatar
Rewards Points: 334
Realistically you're going to need 6 inches of insulation at a minimum which wouldn't leave any of the rafters exposed anyway. You could certainly use spray closed excel form for the insulation and to solve the moisture problem but to get a reasonable R value it's still going to take the 6 inches.
Msradell is offline   Reply With Quote
Old 11-23-2011, 10:35 PM   #6
Rewards Points: 5,336
Purely a personal choice, but since you asked, what's the point? It's not like there's an ascetic jewel you want to keep from being buried.
Ron
B. Franklin 1759
Old 11-24-2011, 09:50 PM   #7
Registered User
Rewards Points: 526
You need a minimum of R-38, as said. This would probably require replacing the rafters with 2x10's depending on the span and local snow load.
There appear to be 3-pieces of built-up beam, then 5 more? Another picture would be helpful...
Gary
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
exposed electrical wiring in basement ceiling zemdegs Electrical 4 01-03-2011 05:08 PM
Raising ceiling, using rafter ties cibula11 Building & Construction 23 01-20-2010 06:38 PM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 03:02 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
