Exposed 1970's Beam - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-30-2006, 09:42 AM   #1
Exposed 1970's beam
The post on decorative beams was good, (build a box, not buy a beam) And Im trying to save the wood to reuse -so here is a twist on the same type of issue.
My Cedar vertical beams are decorative, and Iím not sure how (or IF) I should remove them. It looks like caulk has been used to fill in 2 nail holes, and seal the foot. There appears to be sheet rock behind them, and no visible bolts or screws or brackets holding them to the base of the ceiling - so how are they likely attached?
Should I take a pry bar to it?
- the goal is to plane / refinish them and re install.
Phieldhouse is offline   Reply With Quote
Old 12-30-2006, 07:27 PM   #2
remodeling pro
Most likely just more toenails that you haven't discovered under the paint buildup. What are you going to do with the ceiling when theycome down. From what I see in the picture, it is going to be a pretty nasty looking situation when they are removed.
troubleseeker is offline   Reply With Quote
Old 01-01-2007, 05:23 PM   #3
What's a vertical beam?
mighty anvil is offline   Reply With Quote
Old 01-01-2007, 06:40 PM   #4
Rewards Points: 6,652
They run from floor to ceiling (ie Support Column or Timber). A Horizontal Beam runs across the ceiling structure.
Old 01-01-2007, 11:04 PM   #5
I hope you are kidding.
Old 01-02-2007, 06:29 AM   #6
General Contractor
joasis's Avatar
Originally Posted by gregzoll View Post
They run from floor to ceiling. A Horizontal Beam runs across the ceiling structure.
Could you maybe post a picture or print? I would also like to see a vetical beam.....maybe it is my lack of experience!
What the picture above shows are decorative "posts" supporting decorative (non-structural/non load bearing) beams.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 11:41 AM
Cracked Basement Beam lpcon Building & Construction 12 04-12-2007 07:47 AM
Hanging a beam/rafter from a beam snmhanson Building & Construction 4 01-11-2007 10:37 PM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 10:51 PM
