Experiences With Vinyl Soffit For Porch Ceiling? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 08:23 AM   #1
Rewards Points: 150
Experiences with vinyl soffit for porch ceiling?
My father, who passed away some years ago, installed vinyl soffit (12" wide, 3 sections of 4") on his porch ceiling. But he added 2 visible surface screws between the 4" sections of the vinyl. My guess is he thought it would sag otherwise (probably there was insulation above). My mom can't remember why.
Would it really sag if you use > .039 thickness when installed overhead properly on a flat surface?
I'm ready to order and wanted to choose beadboard, but if there's any chance it will sag I'll choose the plain and do it like he did. It doesn't really look that bad.
NancyNGA is offline   Reply With Quote
Old 07-11-2011, 09:50 AM   #2
Rewards Points: 5,336
It won't sag if there is adequate framing above to nail to. Whether it's vinyl or beadboard. If you're using 3/4" beadboard, you can have the framing 24" apart. Otherwise 16" would be the widest for either vinyl or 1/4" beadboard.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
NancyNGA (07-11-2011)
Old 07-11-2011, 10:26 AM   #3
Rewards Points: 150
OK. I should have said beaded (pattern) vinyl soffit, not beadboard. But I understand what you're saying. If it won't sag 16" lengthwise, then it shouldn't sag 12" sideways. Thank you.
Old 07-11-2011, 07:25 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
no thats not true,it is strongest lengthwise the direction the grooves are going
the beaded soffit panels are narrower-more nails less sag
your Dad sounded like a smart man
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
NancyNGA (07-12-2011)
Old 07-12-2011, 08:39 AM   #5
Rewards Points: 150
Tom, the more I think about what you said, I just know that 12" stuff will sag eventually. Searched for narrower (8") soffit, and it appears the companies producing those only sell to contractors. I better go with the plain (unbeaded) soffit. Thank you.
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
vinyl soffit anthony Building & Construction 1 10-09-2005 02:46 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
