Expansion Space For Raised Panels? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-30-2015, 02:21 PM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
Expansion space for raised panels?
I am planning on finishing out a wall in my basement with raised-panel wainscot, made of poplar. The panels are approximately 21x23. In an indoor environment with panels less than 2', do I have to worry much about expansion space between the stiles?
Thanks!
Expansion space for raised panels?-wainscot.jpg   Expansion space for raised panels?-wainscot2.jpg
hyunelan2 is offline   Reply With Quote
Old 09-30-2015, 04:24 PM   #2
Rewards Points: 249
Depends on the humidity swings in your basement, but I'd definitely factor movement in. Consider that most solid-wood raised cabinet door panels are not 2' wide, but they still require some movement. I would just pick up some spaceballs, cut your grooves slightly deep to accommodate them, and install them around the edges. $6 per 100, if nothing else, it's cheap reassurance.
http://www.amazon.com/Space-Balls-Ba.../dp/B0006LA198
Durt Ferguson is offline   Reply With Quote
The Following User Says Thank You to Durt Ferguson For This Useful Post:
47_47 (10-01-2015)
Old 09-30-2015, 04:32 PM   #3
hyunelan2's Avatar
Rewards Points: 682
Even before you posted, I had ordered that exact item from Amazon. Thanks!
The Following User Says Thank You to hyunelan2 For This Useful Post:
oh'mike (10-01-2015)
Old 10-01-2015, 09:00 AM   #4
Rewards Points: 249
Good call! Peace of mind, and as long as your grooves are the same depth on sides/top/bottom, they have the added benefit of self-centering the panel. Don't forget to finish the panels ahead of time, before you put them in the frames.
NickWa's Basement Renovation NickWa Project Showcase 50 07-01-2015 03:16 PM
can I mount an expansion tank in the crawl space? 211 Plumbing 11 03-27-2015 07:51 PM
Creating a working space helpinggirl General DIY Discussions 10 11-14-2012 09:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 03:10 AM
