Existing Wall Insulation - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-15-2009, 03:07 PM   #1
Lightbulb
Existing wall insulation
Have a cabin in upper Michigan I would like to add wall insulation. I hope not to pull off all the siding but to add blown in insulation. Can any one suggest the best cost efficient way
dpv53 is offline   Reply With Quote
Old 11-16-2009, 05:00 AM   #2
What type of siding? What type of existing insulation? Is there a vapor barrier? What is the interior finish wall material? How old is the house? Are you familiar with building practices(do you know where studs/headers are)? Is it standard framing, a box with a roof, or is it cut up with multiple levels/ half levels/ roofs intersecting with walls?
CustomBuild is offline   Reply With Quote
Old 11-16-2009, 07:58 PM   #3
2X4 walls 16 inch centers vinyl siding. Built in the 40's remolded since. Fiberglass or no insulation now. Doubtful of vapor barrier
Old 11-16-2009, 09:02 PM   #4
Civil Engineer
Rewards Points: 4,956
I hired a crew to blow in cellulose into the walls of my house. Very cost effective. I don't think you can easily find a powerful enough blower for cellulose into walls at the usual suspect big box stores, probably more cost effective to hire someone with the right equipment to do it. They will know all about how to cut the holes and patch.
Daniel Holzman is online now   Reply With Quote
Old 11-16-2009, 10:49 PM   #5
Registered User
Rewards Points: 526
"Can any one suggest the best cost efficient way" ------ DIY: http://www.karg.com/pdf/Insulaton_de...and_Biddle.pdf
Be safe, Gary
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Knee Wall Insulation nebaggie Building & Construction 2 09-30-2009 09:51 PM
Adding insulation to a wall Ohming Building & Construction 5 08-27-2009 01:52 PM
Insulation in an interior wall Avramel Building & Construction 1 03-10-2009 05:22 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
