Exception? To Using Treated Sill Plate For Basement Walls - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 03:30 PM   #1
Avid DYI'er
BriBri's Avatar
Exception? to using treated sill plate for basement walls
I have a relatively new house (built in 2000), and the foundation was coated with some kind of tar-like or rubber-like black substance up to about 2 feet above grade level. I am considering finishing off about 1/2 of the basement area into an additional family/rec room. The basement (concrete) walls never show any signs of moisture and are very smooth, and the floor is very smooth and level. The basement in general is very dry.
My question is: Can I use simple untreated 2x4 for the sill plate of the walls? It's a little cheaper than treated lumber. But, I am wondering if I should ere on the side of caution.
BriBri is offline   Reply With Quote
Old 12-13-2011, 03:39 PM   #2
when i was in fla they had to use pressure treated for bottom plates on the concrete but they would also let them use regular 2x4's with felt paper between the 2x4 and the concrete. depends on what the code is in your area.
Old 12-13-2011, 03:41 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Concrete never completely dries from the day it was poured, and untreated lumber will absorb moisture. Don't cut corners here.
titanoman is offline   Reply With Quote
Old 12-13-2011, 05:11 PM   #4
Registered User
Rewards Points: 5,266
Unless you can prove to the Inspector there was a plastic previously installed under the slab; 3. Sills and sleepers on a concrete or masonry slab that is in direct contact with the ground unless separated from such slab by an impervious moisture barrier. From- http://publicecodes.citation.com/ico...9_3_sec017.htm
You also need to caulk the plate/slab joint as it will be the new thermal barrier; http://publicecodes.citation.com/ico...002_par027.htm
Or, just use a poly sill sealer as it will create the air barrier required by code and give a thermal break to your slab/footing/earth from the warmed wall bottom plate. No heat sink. Also a capillary break (without plastic under the slab). Treated lumber is not waterproof (unless graded such) and water will wick through it to your framing; http://www.greenbuildingadvisor.com/...-building-code
Tar paper is more vapor permeable (5-30 perms) the wetter it gets. Composite decking is made with 50% wood pulp, it will mold.
Gary
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
Damaged Sill Plate/ Rim Joist bignateyk Building & Construction 4 04-28-2010 09:09 PM
Rotted Sill Plate and Joists jhawk4ever Building & Construction 2 08-30-2009 09:03 PM
doing up a basment littleparr Building & Construction 7 04-08-2008 09:28 PM
