European Hinges For Curved Kitchen Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 04:16 PM   #1
European Hinges for Curved Kitchen Cabinets
I'm trying to semi-update my kitchen by replacing the hardware on the kitchen cabinet hinges. Currently, I have overlay type hinges like these:
http://www.homedepot.com/Tools-Hardw...atalogId=10053
I have also face frame cabinets.
I would like to replace the overlay hinges with the European style totally concealed hinges. My problem is my cabinet door sides are curved. On the side closest to the cabinet, there is a 3/8" overlay of the cabinet door on the face frame. However, at its furthest distance, the overlay of the cabinet door on the face frame is 5/8"
To keep the cabinet door from hitting the face frame when the door swings open, I assume I would need to buy a European style hinge for a 5/8" overlay?
However, if I do that, all of the European hinges say I am supposed to drill the 35mm hole to hold the hinge cup 3mm from the edge of the door. If I drill the hole for the hinge cup 3mm from the 5/8" edge, then part of the hinge cup will stick out and will not rest completely inside the door (due to the curved cabinet edge).
Any suggestions on how to deal with this? All the DIY instructions assume a straight corner cabinet door edge and are of no help to me here. Should I drill the hole for the 35mm cup further away from the curved edge so that the European hinge will be completely inside the door. If so, what size faceframe overlay hinge should I purchase?
Thanks for your help!
thiftyspender is offline   Reply With Quote
Old 04-18-2016, 12:34 PM   #2
I have this same issue. Did you ever find a hidden hinge that worked?
MsColoradoDIY is offline   Reply With Quote
Old 04-20-2016, 08:00 AM   #3
Rewards Points: 810
Re: European Hinges for Curved Kitchen Cabinets
Check wood working sites or Blum for the pictures. Each hinge comes with illustrations for applications. You also need jigs for the holes and some jigs may be hinge specific or universal.
carpdad is offline   Reply With Quote
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Help! Can't remove old hinges hardware from kitchen cabinets. sabrosonics Remodeling 1 03-08-2008 02:29 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
