#1 |
erect 30' partition wall
I need to erect a partition wall in an old supermarket that is being converted into another store The owner has requested that I do the work, however I am a flooring contractor and need some help on what best to use- They have requested metal studs but what size studs to use and what should be the proper guage
Thanks Ed |
#2 |
Civil Engineer
This sounds like a commercial job for which I assume you are getting paid. This is a DIY site, you probably should check out the contractor side of things. It also sounds like you need a design for the project, so maybe you need an architect? Or at least plans from the owner.
#3 |
Moderator
I agree with the above. You also need a permit to convert to double occupancy. This would include the electrical, fire-wall and possible egress required.
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Ceiling support for partition wall? | hohadcr | Carpentry | 5 | 09-28-2009 09:38 PM |
| Partition wall supported by subfloor | benjamincall | Building & Construction | 2 | 06-13-2009 10:47 PM |
| Loads on a partition wall | acyate | Building & Construction | 8 | 03-01-2009 12:02 AM |
| A Garage Steel Stud partition wall | PaliBob | Building & Construction | 8 | 02-16-2009 04:32 PM |
| Atlantic-need your opinion on markd's comments about my vapor barrier? | yummy mummy | Building & Construction | 11 | 03-07-2007 10:47 AM |
