Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-23-2012, 08:47 PM   #1
Entry Trim
I have a drywall entry way into my kitchen that I installed 1 x 6 ripped as a jamb and installed trim around the opening. When I installed the trim i put the trim flush with the jamb. It had about an 1/8" gap and when i filled it with caulk it still shows the seem. Now looking at other doorways i notice i should of set the trim about an 1/8" away from being flush so i could caulk the corner where the jamb and trim meet.
My question is could a rip a 1/4" piece of plywood and glue/nail to jamb to give me the corner to caulk and make it a smooth transition from the jamb to the trim? I can upload a picture tomorrow if needed. I wanted to rip it all down and start over, but my overuse of nails made that near impossible. Thanks for the help.
Jmpotter2004 is offline   Reply With Quote
Old 10-23-2012, 08:55 PM   #2
Entry Trim
easiest way is to pull the trim off, move it back from the edge about 3/16 and cut a new pieces. it will never look right trying to add a piece on. if you can take the jamb out and cut it smaller then your trim would work and you would have a reveal. the width would need to be 3/8 smaller and 3/16 lower in height.
Old 10-23-2012, 10:37 PM   #3
Entry Trim
You do know they sell jambs already the right width, rounded edges and a dado already in the head piece.
Old 10-24-2012, 12:03 AM   #4
Entry Trim
I figured that was what would need to be done. I didn't want to remove the drywall and a standard door jamb would not fit due to the drywall. So i ripped 1 x 6 to the proper width and installed. They look good except for my mistake with the trim. I'll remove the trim and if I cause to much damage i'll just take it down to the studs and install standard jambs. Thanks for the info.
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 11:29 PM
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 01:21 AM
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 11:28 AM
Entry door size 32" to 36'? Trim issue 4just1don Building & Construction 1 08-20-2009 06:55 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
