Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-04-2009, 10:28 AM   #1
Wolf
Default Entry Stair Case
I am planning to remove my existing entry stairs and replace them with ones that meet current code and look a lot better than the 30-year old stairs. I plan to build something similar to the picture, although my stairs will be open on both sides and therefore have two skirt boards. Two questions:
1. I plan to miter the corners for each riser (just think it looks better) but am concerned about making very accurate miters in the skirt board which will require different tilt from my saw. Any advice about how to make these miters? I have a good circular saw but it tilts only one direction. I also have a good compound miter saw that tilts in both directions and have not tried it yet on a piece of scrap but I think it may be the best option. I understand that in either case, I'll have to finish the cut by hand.
2. I'll have two tread returns on each tread. Since the distance "between the horns" of the treads is fixed, the distance between the two skirts has to be very exact. Any advice about how to keep the joint between skirt and tread return clean and tight?
Thanks in advance for your advice.
ralphfravel is offline   Reply With Quote
Old 11-04-2009, 09:03 PM   #2
Default My experience........
  1. I used a table saw, then finished the cuts by hand. Measure three times and cut once!
  2. The return on the tread can be removed rather easily. Nailed but not glued. You can always knock it off the tread, cut the tread to the correct length or minor angle change, then reattach the return piece.
MI-Roger is offline   Reply With Quote
More On This Topic
Learn how to adjust neck tilt to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Having the right tires on your car during a drag race can easily make the difference between winning and losing. Knowing how to select the proper drag racing tires will depend upon many variables, such as the type of car you drive, the type of drag... Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
Traveling in Uruguay can be a lot of fun, especially if you know how to dress for the climate. With a little bit of research, you can rest assured that you'll be properly dressed for a trip to Uruguay no matter what the weather is like. Read More »
Hi, my name is Susan Jacobs a Personal Style Image Consultant and I'm here today on behalf of Expert Village to talk about dressing the petite body. In this clip we're going to talk about function. Function of your clothing is very important to consider... Read More »
Removing stair case yankep Carpentry 4 10-20-2009 11:55 PM
what's the safest way to install a chandelier over a stair case? diy'er on LI Electrical 18 08-01-2009 05:15 PM
some questions on stair case skirt boarding (how to measure, cut, materials) dwichman Carpentry 2 04-06-2009 07:40 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 07:18 AM
Stair framing question stubborn1 Carpentry 6 01-19-2009 01:12 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
