Entry Doors E - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-11-2010, 08:39 PM   #1
Smile
Entry Doors e
Good Afternoon. We have fiberglass exterior double doors, (the woodgrain ones), that were in the house when we bought it. I believe they were a prehung unit. We would like to have glass added to the doors which already have etched areas that would look great with glass installed. We don't want to replace the doors with another prehung unit. What is the best and least expensive way to give our home the the natural light it needs with out breaking the bank?
webbgurl is offline   Reply With Quote
Old 03-12-2010, 06:59 AM   #2
You may be able to cut out the raised panels and get glass from the door manufacturer. Is there a brand name anywhere?? Or you could have insulated glass units made locally.
Old 03-12-2010, 09:52 AM   #3
entrydoors question
I don't see a brand name for the doors. Only Hager on the hinges, and Endura on the strip on left entrydoor. here's a pic of the doors:
Entry Doors e-belmont-inside-door-1.jpg   Entry Doors e-belmont-inside-door2.jpg
Old 03-12-2010, 09:59 AM   #4
Rewards Points: 5,336
I wouldn't modify the door unless you can contact the manufacturer for guidance.
Ron
Old 03-12-2010, 10:11 AM   #5
the arch will be the problem cost wise
The older I get the better I was
Old 03-12-2010, 11:17 AM   #6
Entry doors
Ron
Why is it important to contact the manufacturer? Maybe the seller can tell us where he bought the door. We bought the house in December and we just want some light in the entryway. We found a couple of places that say a carpenter can measure and cut the holes, they will cut the glass and install it for a fee.
Old 03-12-2010, 11:26 AM   #7
the door can be modified, i would only take out the top panel but even that may mess with door integrity thus talk to manufacturer. i have made changes like you want and you can get cheap plastic frames with glass or a custom mill shop can make something classier. some companys have retro fits for this
Old 03-13-2010, 02:04 AM   #8
Entry Doors
Thanks so much for all the great advice!! I'll let you know how it turns out.
Old 03-14-2010, 10:44 AM   #9
Take a look at the top of the door, the very top flat surface, see if it has a name, Therm-Tru, Masonite, Plastpro, etc. Or a model number you can search on google to come up with the manufacturer. All three make an insert for that style door, I'm sure there are other manufacturers out there. Other than that, get some good measurements of the top panel width, height, arch, and see if an existing glass and frame would fit. Find a shop that does just doors, and they should be able to help.
cantwin1 is offline   Reply With Quote
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 10:32 AM
Sealing Entry Double Doors SPS-1 General DIY Discussions 1 10-12-2009 06:46 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
Cost to replace entry and screen doors?? kiss44 Carpentry 6 01-30-2009 10:46 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
