Entertainment Center Modification - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-15-2011, 12:35 PM   #1
entertainment center modification
I'm definitely not going to tackle this myself, will get a carpenter if it's possible. I have a big oak entertainment center with an opening for 27" tv, and I want to have it cut down so I can use the bottom for my new tv. I need a good carpenter in the Pittsburgh area!
Alwaysbusy is offline   Reply With Quote
Old 01-15-2011, 01:03 PM   #2
Experienced
Jackofall1's Avatar
Did the same thing to mine, worked out great.
Old 01-15-2011, 02:10 PM   #3
Any chance you have photos, or any suggestions on how it was done? I be getting a carpenter to do it, but I suppose I should give him some ideas. Thanks Diane
Old 01-15-2011, 06:14 PM   #4
Experienced
Jackofall1's Avatar
What I did was set up a temporary guide / straight edge, used a finishing blade in my circular saw, I cut the top portion of the section off. I then capped the sawn edge with a molding piece, which came from the top of the cabinet.
Looks like it was built that way.
Mark
Old 01-15-2011, 07:17 PM   #5
A good idea to put tape along where the cut will be, mark for the cut on the tape and also score the cut line with a knife. Where possible, cut on the hidden side of the unit. If you're hiring a carpenter, at least make sure he's a decent finish man with some experience with this
mrgins is offline   Reply With Quote
Old 01-15-2011, 09:34 PM   #6
Entertainment center
i really appreciate the info, now I know it can be done. My next step will be to find a carpenter.
Red LED lighting inside of In-Wall Entertainment Center HABSFAN2006 Building & Construction 5 11-23-2010 03:38 PM
Custom Entertainment Center and Radiator Cover slickgt1 Project Showcase 6 04-30-2010 11:24 AM
installing recessed lights, entertainment center overload? fabian Electrical 5 01-13-2010 01:25 PM
Entertainment Center Help in Chattanooga TN bemgolf Home Theater 1 07-18-2007 11:29 PM
Entertainment center baldeagle51 General DIY Discussions 7 10-04-2005 11:34 PM
