Enhancing Redwood Panelling - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-11-2007, 02:59 AM   #1
Enhancing redwood panelling
My kitchen has redwood siding that is in quite a good shape but still needs enhancing. Is it enough to just sand it and then refinish?
Butterfly is offline   Reply With Quote
Old 12-13-2007, 07:13 AM   #2
If it's still in a good shape, sanding and refinishing should be enough
(but don’t forget to clean it first).
But in some cases it is better to use a chemical stripper first in order to
strip the panelling from its finish, then sand and refinish it. It depends
on how old your panelling is and how much effort you are ready to put into
repairing it.
There is a good article discussing a similar issue:
http://en.uk.allconstructions.com/portal/categories/176/1/0/1/article/198#ar
Takeshi is offline   Reply With Quote
Decking - Redwood vs. Cedar davidr Building & Construction 3 08-26-2007 10:31 PM
re-using redwood fencing - a good idea? gulleyj Building & Construction 1 08-08-2007 09:40 PM
Painting over panelling - seek advice deb14905 Painting 13 10-13-2006 07:26 PM
Covering Wood panelling peggy General DIY Discussions 6 10-08-2005 09:55 PM
