Engineered Wood-white Risers - Nosing Tounge - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-20-2009, 09:33 AM   #1
Serious Do It Myselfer
Engineered wood-white risers - nosing tounge
I am getting ready to install glue-down engineered maple flooring on my new stairs and need a bit of advice:
I have purchased the nosing for each step which has a groove on the backside. I would like to install the boards parallel to the run (lots of short boards). Should I make a tounge in the end of each board to insert into the groove in the nosing? I will lay my first board in the center of each step so the width of the last left and right board will be the same.
I would also like to use 1/4" or 1/2" white melmine for the risers (glue on) if I can find it. It would be easy to clean scuff marks and be pretty durable I think. I would install the risers over the top of the boards on the steps to cover the expansion gap.
Speaking of expansion gap, I'd like to fit the boards tight to the sides of each step (trim would look terrible) - will this be a problem? Any thoughts would be appreciated.
Thank you
Jim W is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Glue and staple engineered wood on stair treads? cej22 Flooring 1 09-23-2009 10:13 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 08:18 PM
Wood Interior On Patio Door with White Moulding tom_patriot Remodeling 3 12-06-2006 05:51 PM
