Ending Chair Rail Between 2 Undivided Rooms - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 03:31 PM   #1
Ending chair rail between 2 undivided rooms
I have a town house in which the dining and living rooms are connected and do not have any separation on the wall. My goal is to add chair rail to the dining room and paint a second color on the lower portion of the wall. I added some pictures to give an idea of what I am talking about.
My question is, what is the best way to end the chair rail on an open wall, but also end the paint underneath at that same point?
Any advice would be greatly appreciated!
Ending chair rail between 2 undivided rooms-mail.jpg   Ending chair rail between 2 undivided rooms-chair-rail.jpg
BCDAN is offline   Reply With Quote
Old 01-03-2012, 03:43 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,208
return it into the wall via cutting a 45 degree mitre on it the same as at an outside corner, then cut a small return peice that glues onto the end which will mke it look like its coming out of the wall
woodworkbykirk is offline   Reply With Quote
Old 01-03-2012, 03:53 PM   #3
What about the painted wall underneath? I thought it would look strange if the paint in the dining room just ended at the point where the chair rail stops.
Old 01-03-2012, 04:13 PM   #4
Rewards Points: 13,712
I would use a base block, a piece of beaded door casing and a rosette at the top. The chair rail would just end up againt the rosette.
I'd use my ossilating saw to cut out the base board for the base block.
Old 01-03-2012, 04:58 PM   #5
Old School
Willie T's Avatar
I'd just 45 it, and go down, through the base, and kill it at the shoe.
Willie T
Old 01-03-2012, 05:49 PM   #6
Retired carpenter
1x4 floor to ceiling, chair rail butts to it. Shape it on the bottom to go over the baseboard nicely.
abracaboom is offline   Reply With Quote
Old 01-03-2012, 06:26 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Maybe you could install one of these half columns about 42- 48".
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-03-2012, 06:48 PM   #8
KemoSabe
loneframer's Avatar
I'd put a faux column in to give each room a defining separation.
It can be done by simply affixing a 1x6 to the wall vertically and applying base molding, collar and crown around the top. The chair rail can then finish into the "column".
The pillars on each side of this door is the only example I have pics of to give you an idea.
It's nothing more than layers of 1x and built up moldings.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 01-03-2012, 06:52 PM   #9
Old School
Willie T's Avatar
................. Or just make a "flush post" 42" high (basically chair rail height) with a cap on top to let the rail die into.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
mae-ling (01-04-2012)
Old 01-04-2012, 01:06 PM   #10
Thanks for the ideas, guys. I think I can definitely work something out now. I'll post some pictures later when I finish it up.
Old 01-05-2012, 10:44 AM   #11
My wife and I are actually putting this house up on the market soon, and we were also going to add crown moulding. I was planning on using a size comparable to the baseboard (which is about 3 1/4 inches). I read that the baseboard, chair rail, and crown should be roughly the same size. The ceilings are 8 feet. My real estate agent said that I should use as big a crown as is affordable. Is this good advice? What size would be ideal?
Thanks again!
Old 01-05-2012, 11:28 AM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Thanks again!
No, you do not want to use a very large ceiling mold on an 8 foot ceiling as it will make the room look shorter, 3 1/2 should be fine.
Jim
Installing chair rail over uneven sheetrock krazykarr Drywall & Plaster 10 12-19-2011 11:51 PM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 12:42 PM
Painting/staining crown moulding and chair rail Gypsy601 Interior Decorating 8 07-05-2011 03:51 PM
Unique Chair Rail Obstacle mormegil Interior Decorating 4 06-03-2011 06:56 PM
Wallpaper, chair rail, and baseboard. What order? family_man Painting 11 05-26-2011 05:22 PM
