Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-23-2011, 02:25 PM   #1
Question
Encasing a brick fireplace in wood
Hello,
I have a floor to ceiling brick fireplace that I am wanting to incase in a wood frame that I will paint white.
I have done several projects in my house by myself including retiling two bathrooms, tiling my kitchen counters and backsplash and installing a wood floor so I'm thinking that if I could do those projects I should be able to do this.
From what limited information I've managed to find online, it seems that the best way to do this project is to attach a frame to the brick that I will then nail or screw the covering to.
I am wondering what type of wood I need to use for the framing. I don't want to use anything that will make the fireplace protrude out too much more than it already does.
Also, what type of wood is best for the covering?
I intend to tile the top of the hearth and around the sides of the fireplace opening in black marble.
Another situation I'm concerned about is the brick brackets that hold the mantel. I'm thinking covering them in wood could be a bit of a challenge and might turn out looking a little odd because of the shape.
Any tips and/or suggestions are so greatly appreciated! - Thanks.
Laborfree is offline   Reply With Quote
Old 10-23-2011, 04:00 PM   #2
You can use 1x3's or 1x4's to build the frame. If you're painting it, I'd use 3/4" birch ply for the wide areas and clear pine for the smaller pieces.
You just need to plan the design around the unfinished ply edges.
Ron
B. Franklin 1759
Old 10-23-2011, 05:06 PM   #3
Super Moderator
Those bricks could be knocked off easily enough.
Use a cold chisel to score a break line at the wall--and then smack them with a hammer--they will break at the score lines.
Old 10-23-2011, 08:40 PM   #4
STAFF
BigJim's Avatar
Be sure to keep the wood 8 inches away from the fire box on the sides and 12 inches above the firebox.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Tags
brick, fireplace, mantel, masonary, wood incaseing
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Replacing a wood with a direct vent fireplace Travlnman Building & Construction 0 07-25-2011 07:31 PM
Remove Brick Fireplace Clemsig07 Building & Construction 1 04-12-2011 09:59 PM
Can you seal brick on fireplace? mrs1885 Remodeling 3 03-29-2011 11:52 AM
OK to tile over vent/gaps on brick fireplace? roxksears Remodeling 4 01-22-2010 01:48 AM
