Electric Cable To Detached Garage - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 10:30 AM   #1
electric cable to detached garage
I'm running electric cable from the house to the garage. Is it against code to enter the garage with the cable next to a door?
bmorekid is offline   Reply With Quote
Old 12-31-2011, 10:35 AM   #2
Rewards Points: 13,978
No but you need to have it in gray PVC and an LB where it enters the building.
I'm aware you did not ask this but, what size wire did you run? How far under ground did you run it?
What type wire did you run.
You do plan on having a panel in there, right?
If it's detacted your going to need two ground rods.
Old 12-31-2011, 10:49 AM   #3
Framing Contractor
Call your building department and ask them. You need permits and inspections anyway. Were you planning on getting them?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-31-2011, 11:11 AM   #4
UF cable 2 gauge 3 wire with ground to a subpanel. why do i need two ground rods?
Old 12-31-2011, 11:29 AM   #5
It's code now in VA, I believe they need to be at least 2' apart.
The last three garages I built it was checked for by the building inspector.
Old 12-31-2011, 12:08 PM   #6
Framing Contractor
Another question you should be asking your building department. You getting permits and inspections....or will you avoid this question again and plan on doing electrical work illegally.
Joe Carola
Old 12-31-2011, 03:03 PM   #7
is it considered illegal? didn't know that to be honest. maybe i will. what kind of consequences do i face without it? didn't mean to ignore you. thanks for your response and help.
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 05:34 PM
changing location of electric service to the detached garage from the house. marlowc2 Electrical 3 06-12-2011 11:30 PM
Detached Garage sirsparksalot Electrical 16 10-18-2010 01:34 AM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 04:53 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
