Edgeband In Three Passes - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 05:29 PM   #1
edgeband in three passes
I have a woodworking project and uncertain how/whether to proceed and I am hoping you might have some insights that will help me.
Ive got a solid core firedoor that Ive turned (almost) into a coffee table. I am wanting to round the corners with a radius of about 4 to 6 and iron on preglued wood veneer edgebanding all the way round which, after some internet research, I feel confident enough to apply.
The rub: the door is 1 thick and the banding sold is but . This means placing three strips side-by-side to fully cover the MDF edges. I would like to make the center band a lighter color wood for decorative effect which would necessitate cutting a wide strip of the veneer almost 20 in length and that is where Im stuck. How to accurately and effeiciently cut this thin strip w/out spending a lot of money on some specialized tool that Ill never use again.
jc47 is offline   Reply With Quote
Old 06-07-2012, 05:44 PM   #2
DIY staff
Rewards Points: 7,174
You are looking in the wrong place---rolls of veneer are sold for refacing cabinets---It's been years since I have used it--but I believe that is 3 inches wide---easily found from a refacing supply house--I vaguely remember seeing it at Home Depot--
Old 06-07-2012, 07:10 PM   #3
In a little over my head
Rewards Points: 706
How about doing a 3/4" strip down the middle? Then apply the sides and trim to 1/2" after installed?
ratherbefishing is offline   Reply With Quote
Old 06-07-2012, 07:25 PM   #4
Hadn't thought of that. However, the question in my mind is how do I center the middle strip? Just eyeball it?
Old 06-07-2012, 11:30 PM   #5
Rewards Points: 706
Set your combination square to 1/2". Scribe with pencil. Align center strip to pencil line.
Ceiling fan wiring. Passes through and no ground. nimchimpski20 Electrical 6 11-12-2010 11:17 AM
What to do with all the shop tools when the shop master passes away ??? JohnFRWhipple General DIY Discussions 8 06-21-2010 08:32 PM
