Eating Bar - Base Construction - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 11:27 AM   #1
I want to replace my kitchen table with an eating bar. The eating bar will have a granite top. The top will be 72 x 30 x 1 1/4 granite. The base will be 66 x 10 x 40 3/4 and attached to the wall at one end and have a 16 in. wide panel at the other end for stability.
To support the weight of the granite top, the base has to be very sturdy. It can be attached to the wall at one end and the floor along its length.
I need help in how to construct the base. I am thinking it will be built of 2x4's or 2x6's and covered with MDF with an oak skin or with 1/4" oak plywood.
Thanks in advance.
Bill
bhumeny is offline   Reply With Quote
Old 11-16-2009, 01:49 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
bh...I think 2 - 2x4 knee walls should hold it.
Attach to wall and floor, should become very rigid when you put an end panel on to tie the two together.
As far as covering it is concerned, your choices are fine, but I would back the 1/4" plywood with something heavier to keep it from getting wavy.
12penny is offline   Reply With Quote
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 06:42 PM
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 06:38 AM
