Easy Siding,Soffit Jig - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 09:17 AM   #1
Just passing this along. Made one recently for a job and it really speeds up the cutting. Find some scrap 1x4"'s and a piece of 3/4" plywood for a base lets say 20"X16".
Attach on top of the base the first long rail. Then double up what your cutting, place along side and install the second long rail. ( I used 1 5/8 screws counter sunk. The screw tips come out a little but thats OK. It keeps the jig from sliding on your table) Their width is determined by what your cutting. If you have two different sizes, go with the larger one. Very easy to make the width smaller later. Then attach one small rail square to the base rails. Place your saw next to that and attach your second rail at the saws width and add an 1/8th for a little play room. Thats it, done.
Reverse your saw blade. Mark your pieces on the very edge closest to you. Set the depth and your cut away.
II Weeks is offline   Reply With Quote
The Following User Says Thank You to II Weeks For This Useful Post:
Tom Struble (01-01-2011)
Old 01-02-2011, 03:47 AM   #2
starkenwolf's Avatar
Cutting table! Made lots over the years...have one out in the shop now...use it sometimes when the table saw is doubling as an extra storage table....
Thanks for the post!
starkenwolf is offline   Reply With Quote
Is there an easy section to cut out one piece of a baseboard? abefroman Remodeling 2 07-28-2010 02:00 PM
I'll have a bunch of easy questions for you gailquilter2 Electrical 4 05-12-2010 08:00 AM
Couple of easy (I think) questions... tigereye Electrical 2 03-01-2010 10:33 PM
Issues with 'Easy Wave' petunias downunder Landscaping & Lawn Care 1 11-20-2009 06:33 AM
Using Easy Board frazierdavidson Flooring 1 01-31-2009 04:29 PM
