Drywalling Basement Ceiling AFTER Walls ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-19-2013, 09:22 PM   #1
Rewards Points: 422
Drywalling basement ceiling AFTER walls ?
My daughter just bought a townhouse, and the lower level room(18' X 17.5') has drywall walls and carpeted floor. They must have planned for a drop ceiling, but never did it. She wants to finish ceiling cheaply, so I thought about drywall. But is it a bad idea to drywall the ceiling after the walls are already done? There are also ducts and pipes to hide. Thanks.
Jim McC is offline   Reply With Quote
Old 08-20-2013, 06:47 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Not a big deal. The benefit to have the ceiling up first is it makes for a tighter joint at the corners and the walls support the edges.
Put some more screws in the edges and it can be done just as well.
Old 08-21-2013, 08:34 AM   #3
Old School
Willie T's Avatar
In an air conditioned basement you may be able to get away doing the ceiling after the walls, though it is still never a good idea.
The ceiling is never to be fastened around the edges. It is to rest upon the wall sheets, and be free to move a little to negate structure settlement and yearly climatic effects on the wood structure... thereby not causing the taped joints to crack.
Willie T
Old 08-23-2013, 02:01 PM   #4
Rewards Points: 29
You will also need to watch for electrical junction boxes that must remain accessible, or any other plumbing or mechanical things that you need access to.
cube17576 is offline   Reply With Quote
Old 08-23-2013, 06:10 PM   #5
DIY staff
Rewards Points: 7,174
If you are hiring out the drywall work, you will find the cost to be about the same as a drop ceiling---perhaps even a bit more---
mae-ling (08-26-2013)
Sound Deadening Basement Ceiling darrylshill Drywall & Plaster 4 06-01-2012 06:01 PM
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 12:36 PM
Drywalling Basement Hall Ceiling artlover13060 Remodeling 10 12-03-2009 07:15 AM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
