Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-16-2006, 12:08 PM   #1
Ira
Drywall to stone transition
I have self taught myself to frame and drywall a 25 foot wall that I am fairly happy with. However, my drywall edge ends at an uneven decorative stone wall. I had anticipated caulking the edge, but now think otherwise due to the gaps approaching 1/2".
Does anyone have any good ideas on how to eliminate this uneven space with an attractive transition? My lack of experience has stymied me. I have some carpentry skills (moulding, framing, etc.) and have thought about scribing trim to the wall, but this seems like a questionable approach.
Thanks in advance for your suggestions.
IraF16 is offline   Reply With Quote
Old 03-17-2006, 03:02 PM   #2
IHI
Just use hot mud on the lil joint between the sheetrock and the rocks, keep a wet rag handy to wipe up any excess mud that gets on the rocks so it's not so hard to clean later.
Or get crazy and break out the quickie saw and cut the rock wall straight and level, then insert a piece of J trim on the outter edge of the drywall and butt it up and then caulk the fine line
Website
IHI is offline   Reply With Quote
More On This Topic
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
Carpentry is a skilled profession that will always be in demand. Homes and buildings don't construct themselves. Woodworking that includes building beautiful cabinets and furniture is a part of carpentry. If you enjoy working with your hands, pick a... Read More »
How to Cut Drywall
How to Cut Drywall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you how to cut drywall. The first thing that we need to do is measure the height of our wall so that we know how long to cut our sheet of drywall. This wall is about 89... Read More »
When a home is remodeled, people often make changes in appliance placement. Sometimes, whole rooms change functionality. When this happens, laundry chutes can become obsolete. Leaving them visible creates the risk of accidental use—and trapped... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about our final sanding and our final inspection. After letting our third coat dry for 24 hours, our transition from sheet to sheet of drywall should be near perfect... Read More »
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Drywall to stone transition IraF16 Remodeling 4 03-18-2006 07:28 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
