Drywall Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-21-2007, 12:13 PM   #1
newer than a newbie...
Rewards Points: 87
Drywall repair
Hi All.
Basically, I have a hole in the wall (about the size of a quarter), which used to be where we ran some speaker cable. I have now managed to run the cable behind the wall directly to the speaker and need to patch up this hole.
Can someone give me the best insigt on how to do it? Polyfilla would not work specifically here because the hole is too big.
I was thinking I need to cut a piece of drywall about the same size and stuff it in there. But how?
mcvane is offline   Reply With Quote
Old 07-21-2007, 01:20 PM   #2
Stuff the hole with crumbled up newspaper. Enough to hold the drywall compound from falling back inside the hole.
Apply joint compound, smooth, let dry, apply another layer of compound (as the first coat will shrink), sand smooth, prime and then paint.
redline is offline   Reply With Quote
Old 07-22-2007, 11:06 AM   #3
Darylh's Avatar
You can purchase " Wall Patches" that are self adhesive. Just get one or cut one about 1 inch bigger than the hole and stick it to the wall over the hole.
Apply two coats of compound sand between coats and prime. Pole or hand sand with 180 grit sand paper the whole wall to take the sheen off and paint away.
Darylh is offline   Reply With Quote
drywall repair around an outlet. Slatherd Drywall & Plaster 7 03-16-2010 05:14 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
