Drywall Over Existing Ceiling? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 08:57 AM   #1
Drywall over existing ceiling?
I want renovate my place and would like to drywall the ceiling without taking down the existing ceiling. Currently there is just fibreboard tiles nailed to the rafters for a ceiling and I don't know if there is a vapor barrier above it or not. The attic has some insulation but it's all dirty and I would like to just add to it if I could instead of removing it. My question is can I just put the new drywall over the existing ceiling or will it cause a mold problem between the 2 surfaces. If there is no vapor barrier currently can I put one between the ceiling and the new drywall?
billybarty is offline   Reply With Quote
Old 03-07-2008, 11:05 PM   #2
Rewards Points: 5,332
More than likely those tiles were put on furring strips installed on the original ceiling. If the house was built before 1960, the ceiling is probably plaster. It started to crack and the homeowner decided to "fix" it the only way he could, cover it up.
So the answer is no, you shouldn't put another layer over what could be a compromised ceiling structure.
Take down the tiles and screw the wood strips to the ceiling joists with the correct length screws. Then install the new drywall to the furring strips.
Ron
Plaster Ceiling and drywall dprasan Remodeling 6 02-05-2008 11:34 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 03:47 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
