Drywall Framing Cost - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 08:44 PM   #1
drywall framing cost
I'm having a 10' high inner wall constructed in my new metal Barndo -- what should I expect for cost per lineal foot with 2x4x10 studs @ 2' centers?
danster44 is offline   Reply With Quote
Old 09-30-2011, 09:19 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
multiply the length of the wall x .75 +1 then add 5 studs per number of studs required.. figure out the amount of track needed.
calculate the sq ft of the wall then divide by 32, this will give the number of sheets..
after that you just need to add bond, mud, screws and tape plus some sandpaper
woodworkbykirk is online now   Reply With Quote
Old 10-01-2011, 09:31 PM   #3
Thank you, but I'm having a framer do the work (I will do the sheetrocking later) -- whats the going rate for framing, including the materials?
Old 10-02-2011, 06:37 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
...how long is the wall?
There really is no going rate. Each job has its own challenges and each contractor needs to charge differently depending upon overhead.
12penny is offline   Reply With Quote
Old 10-02-2011, 07:35 AM   #5
labor rates vary from region to region and one crew to the next. also it depends on the job
Old 10-02-2011, 07:36 AM   #6
Experienced
Jackofall1's Avatar
Hello Dan and welcome to the best darn DIY'r site on the web.
10' high is one dimension, length is the missing dimension........although peeps on this site shy away from estimating as the numerous variables which can't be seen from the office computer. Get a couple of quotes, sounds like a job for a residential handyman. Just make sure the one you choose has all the right credentials, such as a business license, insurance and his own tools.
Mark
Old 10-02-2011, 08:26 PM   #7
Too Old
A 10' inner wall price is what was given by the contractor that looked at the job. If you are not good with that price then get another bid. If you want cost of materials then say where you are at, my price for material will not be the same in Alaska The best advise I can give is do not pay in full, keep money aside for extra's (you are talking about a remodel) Do not think all contactors will screw you and when you find a good one do not make him think you will screw him.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 10-02-2011, 08:31 PM   #8
Rewards Points: 150
Ill do it for tree fiddy. Just pm your credit card info too me.
OhioHomeDoctor is offline   Reply With Quote
Old 10-02-2011, 08:49 PM   #9
Framing Contractor
Cannot be answered.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-02-2011, 09:02 PM   #10
Too Old
That must be per foot
Cost to have a drywall person come in and clean up the walls and ceiling? RyanD Drywall & Plaster 7 04-01-2011 11:37 PM
? Framing flat drywall ceiling in basement bath. misshaley Building & Construction 0 01-17-2010 12:09 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Drywall Taping Cost loosegroove Building & Construction 10 10-22-2007 05:41 PM
