Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-17-2007, 08:43 PM   #1
Default drywall bullnose (kerfed) corners - Help please!
How do you finish bullnose kerf corners around a window??
The windows we installed have a kerf or grove around the wood interior frame. Due to the depth of the window frame I had to fur out the walls before hanging the rock, so my finished wall surface is proud of the window frame to accept the 3/4" bull nose. I have the metal bullnose (kerfed) and everything seems to fit ok. My question is making the inside corners with the bullnose. How do you get the bullnose mitered and held together so you can't see the seam under some mud? I've seen pre-made bullnose corners for the vinyl bullnose beads that are attached to two walls forming a corner, but I have not seen such a thing for kerfed bullnose.
Any help would be appreciated!!
Thanks.
steve1234 is offline   Reply With Quote
More On This Topic
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut window and door casing with the miter saw. You will start with laying the casing flat. This particular kind is really, really tiny, there... Read More »
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
We are going to look a little bit more into 3D right now. First thing you want to do if you are making a cartoon situation or a scene you want to think about we are going to do an inside of a room. Now pick a corner of the room and then here is our floor... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
Curved corners where drywall meets? SouthGAreno Remodeling 8 11-14-2007 02:12 PM
Corners with drywall? Ol' Luke Building & Construction 9 11-09-2006 08:17 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 05:05 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 09:11 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
