Drywall: 1/4" Gap Near The Floor? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 09:05 AM   #16
Old School
Willie T's Avatar
Originally Posted by DrHicks View Post
A thinker? Here?? Shut! Up!
Actually, your explanation was perfect. Thanks.
Stranger things have happened.
Willie T
Old 11-08-2011, 01:43 PM   #17
Hi there,
New to this forum and excited to be here!
I can say from our ongoing project that you should definitely do the floors last! We laid a really expensive tile floor first thing after demo (my contractor Sister in law nearly had a heart attack, and now I know why). We have spent probably double time on every project looking after the floor- covering it up, sweeping, keeping tools from falling on it, and trying to keep it clean. Thank goodness we haven't grouted yet- the drywall has been a mess, and we still have primer and paint to go. It has been a lesson learned the hard way- next time, the floor will be the last project. Good luck!
AlmondJoy is offline   Reply With Quote
Old 11-08-2011, 02:40 PM   #18
Old School
Willie T's Avatar
Also, don't make the mistake of putting the cabinets in before the floor.
Willie T
Old 11-08-2011, 02:45 PM   #19
Single mom, tight budget
Yeah, I'm a thinker. Lol! I had planned on leaving the gap, so my new question is how do I lay the different layers of flooring and make sure that gap is there? Just cut the drywall to 7'8" since the walls are 8', hang it snug against the ceiling, and lay the floor under it when the process is done?
I like to know full details about things because I live in the middle of nowhere and I can't get anyone who knows what they're doing to come help me. Which is why I'm so HAPPY to have found this website!!
girlitomboy is offline   Reply With Quote
Old 11-08-2011, 02:54 PM   #20
Old School
Willie T's Avatar
You going to have baseboards?
Willie T
Old 11-09-2011, 03:57 PM   #21
I managed to save most of the woodwork so the plan is to put the original base boards back.
Old 11-09-2011, 04:20 PM   #22
Old School
Willie T's Avatar
You can hold the subflooring cuts as much as an inch back away from the drywall (assuming it ran all the way down), and you only need to hold the actual finished flooring a quarter of an inch or so back. The baseboard will easily cover that. Flooring isn't going to shrink, it only expands, so it will always be under the baseboard.
Willie T
Old 11-09-2011, 05:33 PM   #23
I know it was previously stated that horizonally is the proper way to hang drywall, but I'm flying solo on this project. Any suggestions?
Old 11-09-2011, 05:44 PM   #24
Old School
Willie T's Avatar
Yes..... Hang drywall vertical or horizontal
And look around at the rest of the thread too.
Willie T
Old 11-09-2011, 06:04 PM   #25
Thank you for the reminder. I appreciate it.
Old 11-09-2011, 08:14 PM   #26
Rewards Points: 5,336
Is there a specific reason I am supposed to leave a 1/4 " gap on the bottom when hanging drywall?
I haven't got an answer other than "that's what I was always told to do but I couldn't tell ya why".
That is why I am here because there's nothing about it in the DIY "bible" I bought and I haven't found any information online other than "oops" cover-ups.
Another question. Which should I do first: the drywall or the floor? I wouldn't think it would make a difference, but that's why I'm asking since I don't know for sure.
Thank you!!
I keep it off the floor in case of water issues. I will leave it off the floor 3/4",except in the basement, then at least 1".
Ron
B. Franklin 1759
Old 11-09-2011, 10:16 PM   #27
Registered User
Rewards Points: 5,204
In a basement, be sure to air-seal the drywall keeping indoor moisture from condensing on the cold concrete/block wall with rigid foam board. ADA--- http://www.buildingscience.com/docum...wall-approach/
http://www.buildingscience.com/docum...lation-systems
Use a poly sill sealer under the bottom p.t. plate for a thermal/air/capillary break from the cold slab/earth.
Gary
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
About to start new wood floor and the first row will be 1/4" out of square. liquidvw Flooring 15 11-26-2010 09:34 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
