Dryvit Vs Vinyl - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 11:42 PM   #1
Dryvit vs vinyl
Which is a better siding dryvit or vinyl
ROSS KOEHN is offline   Reply With Quote
Old 05-31-2011, 07:23 AM   #2
DIY staff
Rewards Points: 7,174
Skip the dryvit---Is Dryvit Dead???? - General Discussion - Contractor Talk - Professional Construction and Remodeling Forum
How about a nice Hardie type of cement siding?
Old 05-31-2011, 07:53 AM   #3
kwikfishron's Avatar
Rewards Points: 176
Welcome to the forum Ross.
The short answer to your short question would be Vinyl.
I’m surprised Dryvit is still being sold. If it’s the Stucco look you want then use Stucco.
If it’s lap siding you like there is are a few material options. Look and compare all of them before you decide.
kwikfishron is online now   Reply With Quote
Old 05-31-2011, 07:46 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
drivit is a brand name
http://www.dryvit.com/home.asp?country_id=1
eifs is the generic,it can be a fine cladding if wall prep and installation is done to specs
Tom Struble is offline   Reply With Quote
Old 05-31-2011, 07:48 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
See a lot of Dryvit failures around here.
It is all in the prep.
XXX
Old 05-31-2011, 08:07 PM   #6
DIY staff
Sadly,Many insurance companies will not insure a home cover in Dryvit.
Old 05-31-2011, 08:08 PM   #7
Rewards Points: 176
Really…..I’ve only dealt with it twice, both times the sheathing was soaked. Even in the field where windows or other penetrations didn’t exist. Installed to specs? I don’t know but I've seen enough to not recommend it.
You just about need to encapsulate yourself in a tent when tearing it off or you’ll have that stuff all over the neighborhood.
Old 05-31-2011, 08:13 PM   #8
Rewards Points: 176
I thought you had to be a “certified installer” to even buy the stuff.
Old 05-31-2011, 08:30 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is a lot of it done here. You never ever see anyone from the company on any job anywhere. All we see is the workers and and their microwave ovens. A-h-h-h-h-h, I love the smell of hot tacos at lunch time.
The faux-stone is the same way. Pitiful, just pitiful. In fact three years ago I worked on a home that was built for 1.5 million. The EIFS and fake stone job was terrible. They were also scheduled to do a fireplace inside. I had a tile job that cost well over 100K and pitched a ***** when I found out who was going to clad the fireplace. I haven't worked for that decorator since then. She got really pissed at me.
XXX
Old 05-31-2011, 10:00 PM   #10
Learning by Doing
Leah Frances's Avatar
Having worked on millions of dollars of EIFS litigation I would hesitate to recommend dryvit. It's not an inherently flawed system.... But only 1 or 2 percent of it is installed correctly. Even with a sterling install it probably will hurt resale.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
kwikfishron (05-31-2011)
Old 06-02-2011, 07:01 PM   #11
there is no ''inherently'' bad cladding only sloppy or noexistant installation details to say one is better than the other is misinformed,there have been million dollar litigations with every siding....even wood
The Following User Says Thank You to Tom Struble For This Useful Post:
Leah Frances (06-02-2011)
Old 06-02-2011, 07:24 PM   #12
Rewards Points: 176
So how does sloppy or nonexistent installation details play into the melting vinyl siding caused by the neighbors windows?
Who’s at fault with that one?
Old 06-02-2011, 07:34 PM   #13
well the windows are likely faulty,not sure what your point is though Ron,
i wouldnt doubt that the heat reflection problem isn't damaging the plastic finishes we put on wood and fc and being blamed as paint failure or moisture problems
Old 06-02-2011, 07:37 PM   #14
this is really not true,there was at one time a problem with this however
DryVit vs. Vinyl Siding tripower Building & Construction 26 03-27-2010 12:46 PM
Replace DryVit with Vinyl Siding cakebaker Building & Construction 1 11-19-2008 03:29 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
