Drying Pressure Treated Wood - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 06:33 AM   #1
Rewards Points: 139
I have two lengths of 2 by 10 by 7 foot ptw stacked flat on sticks in my shed. The shed can get hot even with the doors and windows opened. I have them in there to quicken the drying process.
Is this a mistake?
rjordan393 is offline   Reply With Quote
Old 08-21-2013, 02:05 PM   #2
Rewards Points: 274
It won’t be a mistake.
alexjoe is offline   Reply With Quote
Old 08-22-2013, 04:58 AM   #3
Rewards Points: 139
Thanks,
I should have done a bit more research in picking the right type of wood for a fascia that is under a soffit. I seen recommendations for southern pine, fir and I level framer series which may be the best choice. Whatever gets installed will be primed and painted and then capped with aluminum. I just want something that will be trouble free.
I am installing a retractable awning next Spring and according to the distributors recommendations, I will need 2 by 10 lumber to mount the brackets.
Back in 1980's, I had a deck built with ptw and all the deck boards cupped and I ended up replacing them about 15 years later. There was one short piece of 2 by 12 attached at a 45 degree angle to two beams that was actually falling apart. I do not think that wood was properly treated either by the manufacturer or by the lack of proper maintenance by me.
Old 08-22-2013, 05:42 AM   #4
DIY staff
Rewards Points: 7,174
Return that wood and get standard /untreated wood.
The chemical in the ACQ treated wood will corrode the aluminum wrap very quickly.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
joecaption (08-22-2013), user1007 (08-22-2013)
Old 08-22-2013, 07:43 AM   #5
Rewards Points: 13,690
Read the big letters on the outside of the box on any aluminum coil stock.
DO NOT APPLY OVER PRESSURE TREATED WOOD.
woodworkbykirk (08-23-2013)
Old 08-22-2013, 01:47 PM   #6
Rewards Points: 139
Thanks Mike & Joe,
I also learned that too through researching the net.
The Following User Says Thank You to rjordan393 For This Useful Post:
oh'mike (08-22-2013)
Old 08-22-2013, 07:09 PM   #7
DIY staff
Joe and I have seen the results and had to fix them---
Old 08-22-2013, 07:36 PM   #8
Too Short? Cut it Again!
If you can afford it, you might think of something other than pine or fir. Redwood or cedar might be less prone to cupping.
Old 08-23-2013, 09:50 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
Originally Posted by rjordan393 View Post
Thanks,
When you say "under a soffit" do you mean the frieze board located under the soffit? fascia board is the board that the gutters hang off of, frieze board is under the soffit on the exterior wall and butts up to the soffit at inside corner of soffit...
hand drive is offline   Reply With Quote
Old 08-23-2013, 10:26 AM   #10
Rewards Points: 139
<frieze board is under the soffit on the exterior wall and butts up to the soffit at inside corner of soffit..>
Yes, then I misnamed it
Old 08-23-2013, 10:01 PM   #11
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
joe is very right.. aluminum cladding thats in contact with pressure treated will literally turn to ash
the first time i saw it was on a sun room that was sheathed with pressure treated plywood then clad.. we had to strip all the old aluminum off, the cover the pt plywood with blueskin so the chemcials wouldnt leach through .then reclad
woodworkbykirk is online now   Reply With Quote
Old 08-24-2013, 05:37 AM   #12
Rewards Points: 139
Thanks all,
I had to settle for hem fir for my 2 by 10. I priced cedar and was quoted $80.00 for a 16 foot length. The hem fir was $20.00 for a 14 foot length. I have it in my shed to dry. Recent wind blown rains got it wet.
Old 08-24-2013, 05:42 AM   #13
DIY staff
You will be fine------odd that the original one rotted out----
Old 08-24-2013, 06:20 AM   #14
Rewards Points: 139
The original is fine. The 2 by 10 will be secured over it. The reason is: The brackets for the retractable awning are too big for the original frieze and require a 2 by 10 to mount them. There is no wall under the frieze. Its an open area with just a roof covering a patio.
Old 08-24-2013, 06:24 AM   #15
DIY staff
Good--then you will be just fine-----good luck and post a picture when you are finished---Mike----
Painting Pressure Treated Wood stephen44 Painting 14 05-14-2016 08:22 AM
Do I need pressure treated wood for outdoor project? gijoe985 General DIY Discussions 15 08-21-2013 08:01 AM
Painting pressure treated wood canvasback38 Painting 3 04-16-2012 07:31 PM
how to treat exterior pressure treated wood handrail dthome4433@comc Painting 1 04-13-2010 06:42 PM
use of pressure treated wood in the garden bscout Landscaping & Lawn Care 7 06-06-2007 11:23 PM
