Drying Out Wood - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 01:21 PM   #1
Post
drying out wood
ive just found a plank of wood in the garden that seems to have been out there a while. its a bit soggy on the surface but not right through as ive sewn into it to check. id like to dry this out and sand it and treat it to be used as my new fire surround. how can i dry it out quickly? it is salvageable? its a little green on the surface but i imagine i can sand it off?
marisa is offline   Reply With Quote
Old 11-04-2012, 01:40 PM   #2
Civil Engineer
Rewards Points: 4,560
First off, you want to use this for a fireplace surround. Are you planning to paint the surround, or do you want a furniture grade surround? As for using a piece of wood that has been in contact with the ground, it is probably too damaged to use effectively, and certainly it would take a long time to dry it unless you have a kiln. My suggestion is to purchase new lumber from a lumber supply store.
Daniel Holzman is online now   Reply With Quote
Old 11-04-2012, 01:43 PM   #3
Rewards Points: 13,250
If it green and has not rotted then most likly it's pressure treated.
Not a great plan to try and use it for what your trying to do.
Linseed Oil bobat Painting 12 05-20-2011 05:22 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Drying wood out JoeT Carpentry 1 05-23-2008 06:28 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
