Driving A Hole Into A Stud - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-07-2008, 10:12 PM   #1
Rewards Points: 1,088
Driving a hole into a stud
Most people use stud finders to ensure they know where the studs are before predrilling a hole for a screw or driving in nails. What do people do also to ensure that the stud doesn't have cpvc or copper pipes going through the exact point that they plan to do the work at?
I know, most builders install steel plates to protect these intersections, but not all do. Even some studfinders can locate copper tubing, but not necessarily cpvc tubing.
handy man88 is offline   Reply With Quote
Old 06-08-2008, 02:33 AM   #2
Registered User
Termite's Avatar
Thermal imaging equipment aside, there's no way to determine where plastic water lines, fire suppression system lines, or DWV pipes run through studs.
For this reason, the code has minimum requirements for protection of plastic pipes. If they're within 1-1/2" of the face of the stud, they need nailguards. Hopefully that code was enforced on the house that you're working on.
Old 06-08-2008, 10:28 PM   #3
Thanks for confirming what I thought.
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 09:08 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
