-   -   Drilling through multiple studs (http://www.diychatroom.com/f14/drilling-through-multiple-studs-11939/)
dailo 09-28-2007 10:53 PM
Is it possible to drill through 3 studs without removing any drywall? I want to mount my plasma on a wall that I have partial access to and I want to hide my cables behind the wall. I have a room to the left of the place I want to mount my TV to hide all my equipment and I have some crawl space to access the back of the wall about half way. Then there are 3 studs that I can't access from up top so I have no choice but to go through them. I was thinking of making my hole to feed my cables and using a right angle drill to make holes from there through the other studs. Just wondering if anyone has ever tried it or am I just wasting time. Thanks!
send_it_all 09-29-2007 12:43 AM
Home Depot and electrical supply houses sell a long (4' ish) drill bit holder for just that purpose. I have two of them and I can hook them together if I need to go through multiple joists like your situation. DO THIS AT YOUR OWN RISK!!!! I have seen people hit wires and water lines doing this. You also need to be very careful not to drill through the back side of the wall, since you are flying blind in a way...It takes a little experience and feel to use the tool right. Also, if there is insulation in the walls, you will have a problem....I would suggest cutting about a 10" wide section od drywall out where you want to run your cables, then patch the drywall when you are finished. If you dont like your chances of doing a good patch job, call a drywall guy or a handy man to do the patch.
dailo 09-29-2007 01:03 AM
Thanks for the tip. Also when going down to the part I have access to I have to drill down a block on top between the two studs. Is it safe/smart to try to remove that piece of wall so I can drill a hole through one of the studs and only have to go through two from the other side. I don't think there should be any insulation as it is an interior wall. Thanks for the heads up about hitting something, definitely need to go slow.
send_it_all 09-29-2007 01:16 AM
I'm not clearly visualizing your situation, so I can't answer your question correctly, but I would still suggest just removing some drywall to access the area. If you decide to try the long drill bit, again...be very careful. Good luck.
Handyman50 09-29-2007 08:31 PM
One other caveat when using a long drill bit. You can easily hit a nail or other obstacle that will deflect the bit. Then, you have a hole where you don't require one.
My son is an electrician. In his daily work, he uses the long bits frequently. Luckily, he is also a very good at repairing sheetrock, because the bits do get deflected occasionally.
crecore 10-03-2007 06:12 PM
can you drill down through the floor chase up the stud bay, go over 3 studs, drill back up and chase again?
dailo 10-05-2007 03:48 PM
Unfortunately it is the basement so I cannot get underneath the wall. Not sure why they would only give me access to half of the wall! The crawlspace behind the wall unfortunately does not go all the way to the point where I want to make the hole. I am going to look around and see how much it costs to patch dyrwall first before I attempt because I think I will most likely need to cut some out.
skymaster 10-05-2007 08:17 PM
Dailo: the cost of NOT cutting out the drywall will greatly exceed what ever the price of repairing the drywall comes to.
