Drilling Straight Holes Without Drill Press - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 06:41 PM   #1
Drilling straight holes without drill press
How can I drill a straight hole without a drill press? Does Harbor Freight sell an accessory? The holes will be 3 1/2 in deep. One option I was thinking of was having a friend drill holes in a 2x4 with his drill press and then using that as a guide. Unfortunately, I can't bring the wooden posts to his house for drilling.
pomelo is offline   Reply With Quote
Old 01-22-2012, 07:19 PM   #2
Old School
Willie T's Avatar
Lay a mirror down on the surface you are drilling, right next to the bit. It will help keep the bit perfectly straight. Works best if you can get hold of a plastic mirror, and drill a hole right in the center....... drill through that hole.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
mae-ling (01-23-2012)
Old 01-22-2012, 07:45 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
there are jigs that you can buy, big box stores have them usually in their specialty drill bit section i believe wolfcraft makes one. lee valley also sells one
http://www.leevalley.com/en/wood/pag...at=1,180,42311
woodworkbykirk is offline   Reply With Quote
Old 01-22-2012, 08:30 PM   #4
Green Hat
Rewards Points: 170
The Kreg kit is nice as well. That is the one that I use often. Drill press would be less time consuming, however I just don't have the space.
Mills314 is offline   Reply With Quote
Old 01-22-2012, 08:59 PM   #5
Too Short? Cut it Again!
As mentioned you can buy drilling jigs but your 2x4 idea sounds promising and cheap. What diameter are these holes though?
Old 01-22-2012, 09:00 PM   #6
Curious but lost you on this. Can you explain further?
Old 01-22-2012, 09:04 PM   #7
Rewards Points: 13,732
What is it your really trying to do. Yes I know you want a straight hole, What's the job your doing?
Old 01-22-2012, 10:25 PM   #8
3/8 inch
Old 01-22-2012, 10:26 PM   #9
Rewards Points: 81
Here's a good link. The CD is a nice trick.
http://www.timberframe-tools.com/tec...ling-straight/
Total Tool is offline   Reply With Quote
Old 01-22-2012, 10:28 PM   #10
The holes are for 3/8" carriage bolts. The will secure a board to the top of the posts. The canopy needs to be disassembled and reassembled multiple times, so I want the holes to be the same on both sides.
Old 01-22-2012, 11:11 PM   #11
Learning Things Every Day
Jay 78's Avatar
This is why I wish all drills had integrated bubble levels like my dad's old Craftsman does.
Under Construction
Jay 78 is offline   Reply With Quote
Old 01-23-2012, 12:27 AM   #12
Carrage bolts do not need a tight hole, just drill the hole over sized.
Old 01-23-2012, 06:57 AM   #13
kwikfishron's Avatar
Rewards Points: 596
Then layout and drill in from both sides instead of drilling all the way through.
kwikfishron is online now   Reply With Quote
Old 01-23-2012, 08:19 AM   #14
Not so new
12penny's Avatar
Rewards Points: 520
+1 Slightly oversized is good. May require blunt force persuasion.
12penny is offline   Reply With Quote
Old 01-23-2012, 08:30 AM   #15
Rewards Points: 2,212
The 2x4 with a hole drilled by friend should be OK. You can take a 2x4 and cut a notch in it, gives you a 2 sided guide. I suppose you could even clamp 2 different 2x4 pieces on in a L shape.
mae-ling is offline   Reply With Quote
Drill Press Safety -- Big Problem ldjnx Tools 6 10-07-2011 03:03 PM
How to drill 1 1/2- 2" wide holes in Logs Pantucci General DIY Discussions 12 09-10-2011 11:52 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 09:53 AM
Why can't I find straight concrete drill bits? DawsonMobley Tools 13 12-13-2010 12:31 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
