-   -   Drilling to outside (http://www.diychatroom.com/f14/drilling-outside-177911/)
benleef 04-23-2013 11:34 AM
Drilling to outside
1 Attachment(s)
Hi all. Looking to add a bathroom vent in my basement bath project.
Have 4" pipe that will vent to outside. Have 4 1/4" hole saw. As you can see from the picture, with the hole saw up against the subfloor above, I would need to drill a little bit through the top of the rim joist.
Is this OK to go ahead and do? a 4" hole saw would maybe make it without drilling the rim joist, but I'm not sure if the 4" venting pipe would fit.
SeniorSitizen 04-23-2013 11:50 AM
Go ahead with the 4-1/4" plan. That knot just below your thumb has already jeopardized structural integrity there so the small amount of material your hole saw removes won't make a bit of difference in that location.
jagans 04-23-2013 07:05 PM
1. A rim joist is fully supported, so it is no problem.
2. You probably dont need a 3 or 4 inch pipe for a vent. 1-1/2 or 2 inch will usually suffice.
TheEplumber 04-23-2013 07:15 PM
199 Attachment(s)
I'd notch and chisel out enough of the sill so that the arbor bit bites real good on the rim joist. As it is- that saw will walk right down the sill.
I've seen a guy get about 40 stitches across his cheek trying something similar. Just saying......:wink:
kwikfishron 04-23-2013 08:05 PM
199 Attachment(s)
I'd do it all with a Sawzall. Had my azz kicked to many times with those bits.
Beauty rings are a wonderful thing. :yes:
And...I wouldn't drill to the outside. Drill a center mark from the inside the go out (to the finish side) and cut it from there.
joecaption 04-23-2013 08:09 PM
I think a few of the other posters are missing what it is your trying to do.
You need at least 4-1/4 for an exhost vent or the back side of the vent will not fit in the hole.
What type siding to you have?
It would be best if you could drill only far enough through that the pilot drill went through, and drill the rest of the way thorugh from the outside to it does not blow out the back side.
jomama45 04-23-2013 08:36 PM
Now you know what it's like reading a large number of your own suggestions. I oftentimes wonder if you are posting in the right thread, or have even read the OP's question when reading your responses.........
one cut 04-24-2013 12:33 AM
It looks to me like his pilot bit wont make it anywhere close to the outside before the hole saw grabs that joist and he breaks a few bones in his hand.
RWolff 04-24-2013 12:41 AM
It looks okay to me, the amount being cut from the joist is minimal, is there a reason that pipe has to go exactly there and not 1/4" further over to avoid cutting the joist entirely?
A 4" hole saw will not work for a 4" pipe since the 4" designation is inside "I.D." diameter, the external diameter is going to be about 4-1/4" or a little more depending on the pipe.
I don't like hole saws this size, I've used them but they have a severe tendency to very suddenly jam and when they do the drill is suddenly yanked in such a way that your trigger finger more often than not presses against the trigger harder in trying to stop the drill from spinning out of control.
At least use a heavy 1/2" drill with a handle on it if you can, so you can use BOTH hands, and go slow and steady.
I was using a 1/2" Milwaukee magnum drill at work with a large hole saw and a handle on it, the damn trigger on that is more of a lever about 3" long, so when you grab hold of the drill you are pressing the trigger, not a good deal.
The saw jammed and the drill tried to spin out of my hands but in the direction that was pushing the trigger lever against my hand, that sure hurt and probably came close to breaking my wrist.
Beepster 04-24-2013 08:47 AM
Joe C has it. Drill the pilot hole outwards from the inside and then drill the 4" hole inwards from the outside.
I like things VERY snug with minimal to no gaps. The 4" hole may not be big enough for the fan vent. I have a little grinding bit for the drill that I basically grind of a tiny tiny bit around the whole circumference of the hole until the pipe just fits. Caulk liberally and screw down from the outside. As this is in a tough to reach place, maybe have the ducting already fastened and slide through from the inside.
I have never ever had a problem drilling the hole. This is the 4" hole bit that has a pilot drill bit as a part of the assemble, correct?
B
