Drilling Holes Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 10:40 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 66
Drilling holes question
This is kind of silly, I'm probably doing something wrong in my method, but I find whenever I drill a hole into something, I have trouble keeping the bit in the same spot until the hole is started. Could is be my method, or maybe my bits? I usually end up guiding it with my finger while making it turn slower so I don't hurt my finger, then once there is a small "Dent" then I can keep it in that spot and continue the hole.
Old 07-23-2010, 10:51 PM   #2
Electrician
Proby's Avatar
You really shouldn't have this problem with wood. When drilling metal the bit tends to walk sometimes, but when you need the hole to be perfect you can use a center punch to make an impression that the bit will fit into so it won't walk. When drilling concrete sometimes the initial bounce will make the bit walk, but you get used to this and compensate.
Proby is offline   Reply With Quote
Old 07-23-2010, 11:07 PM   #3
Wire Chewer
Rewards Points: 66
Never thought of punching the hole,I suppose almost any pointy object such as a big nail would do the trick. When drilling in rough wood like 2x lumber it's not so much an issue, but like, drilling a hole in baseboard for a curtain rod or something where it needs to be dead on, I've noticed it might walk a bit.
Old 07-23-2010, 11:40 PM   #4
Electrician
Proby's Avatar
When drilling wood, just push the drill/bit into the wood to make an impression, then start drilling.
Old 07-24-2010, 12:38 PM   #5
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I agree that you really shouldn't have issues drilling in wood. Your baseboard might be hardwood and, therefor, tougher to drill than 2x, which is softwood. I suspect your drill bits are dull.
WirelessG is offline   Reply With Quote
Old 07-24-2010, 04:25 PM   #6
Civil Engineer
Rewards Points: 4,566
Could be you are using metal bits to drill wood. Metal bits, especially when they are dull, tend to wander when initially started on wood, especially if you are drilling into a knot or similar harder than normal wood. Options as suggested include prepunching (I use an automatic center punch), or using a specialized wood bit such as a spade bit (has a sharp center point built in), a forstner bit (drills very smooth holes, has a small sharp centering bit to start), or a fluted wood bit (has a small, sharp centering bit to keep the bit from wandering).
foundation weep holes for drainage shama144 Building & Construction 12 12-31-2011 12:17 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
French Drain Question RINAIL Building & Construction 5 04-07-2008 08:53 AM
roof ventilation question fred5454 General DIY Discussions 2 01-08-2007 08:34 PM
