Drilling A Hole In Stump To Recess Tuna Can - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-15-2014, 11:28 PM   #1
Drilling a hole in stump to recess tuna can
I need some help. Need to recess a tuna can as perfectly as possible into a stump. Filling it with live mealworms for the bluebirds is the goal of this project. I've been told a hole saw will work but I'm not so sure that's going to accomplish what I have in mind. Would a Forstner bit be a better option? I just need something to attach to my drill that will cut this piece out!!
Cobravenom is offline   Reply With Quote
The Following User Says Thank You to Cobravenom For This Useful Post:
creeper (03-16-2014)
Old 03-16-2014, 12:44 AM   #2
A forstner bit the size of a tuna can will cost you a pretty penny, plus will not handle safely without a drill press. You would be better of with a multitool from Harbor Freight (or Fein or Dremel or Bosch etc)and nailing or screwing the empty tuna can to the place you want and cutting around the can. After you have cut the circle, you can then cut straight lines inside the circle, and then with a screwdriver or chisel you can bend each row until it snaps, and then dig it out.
fotoburger is offline   Reply With Quote
Old 03-16-2014, 12:52 AM   #3
iminaquagmire's Avatar
Rewards Points: 338
That big of a forstner bit wont be cheap. Neither will the holesaw which won't remove the core of wood from the stump. Forstner would be better but hard to find that big. Can't you just screw the can onto the stump?
iminaquagmire is offline   Reply With Quote
Old 03-16-2014, 03:35 AM   #4
Rewards Points: 166
I would probably draw the outline and then drill several smaller holes to the same depth to take out most of the material. Then just finish it up with a chisel.
You could consider a plunge router also, but you would need to spend time making (or money to buy) a circle cutting jig to get a good result. It might not even be worth the effort for a project like this.
A hole saw can get you the outline you want, but you would still have to remove the material in the middle.
As others have said, a forstner bit that big would cost way too much and it wouldn't work well outside of a drill press.
dftc is offline   Reply With Quote
Old 03-16-2014, 05:44 AM   #5
Rewards Points: 12,830
And even if you did bore it out you would just end up with a rusty metal can that will fill up with water every time it rained.
May be better off with something plastic like the bottom of a 2 liter bottle or peanut butter jar, drill a couple holes in the side for drainage and screw it to the stump.
Old 03-16-2014, 07:20 AM   #6
DIY staff
Rewards Points: 7,174
If you have a router, that could be done safely ---
make a round template the size of the hole---then use a straight cutting pattern bit with a top bearing---
tack the template to the stump---route out the center of the opening--then set the bearing against the template to finish off the cut----
Old 03-16-2014, 09:16 AM   #7
I'm a pro with carpet tools and a newbie with carpentry tools!
Sounds like the smaller holes and a chisel is my best bet! Ive never used anything outside of basic saws and bits. Screwing the can to the top of the stump will take away from the photos. I like to practice my iPhoneography! Lol
Thanks so much for your comments. Working on lattice and deck railing today. Figured while at Lowes if there's a tool to make things easier I could grab it.
Old 03-16-2014, 09:39 AM   #8
kwikfishron's Avatar
Rewards Points: 86
Just pick up an inexpensive spade bit. It will remove quite a bit of material at a time, then finish it up with a sharp chisel.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
Fix'n it (03-16-2014), oh'mike (03-16-2014)
Old 03-16-2014, 10:13 AM   #9
Rewards Points: 808
Take a chainsaw and slice 2 & 1/2 inches off the trunk. Take that slab and holesaw a tuna can sized hole right through it. Replace trunk slice. If you want to get anal chisel a drainage channel across the intact trunk, and leave a weep hole on the bottom of the can. I think cans are aluminum and won't rust.
IslandGuy is offline   Reply With Quote
Old 03-16-2014, 11:48 AM   #10
Rewards Points: 256
Soda/beer cans are aluminum. Food cans are tin. I would use a hole saw and chisel out the center will not be that hard and hole saws do not cost that much money. For under $10 with the arbor you can get this at Home depot
JustinK is offline   Reply With Quote
Old 03-16-2014, 12:55 PM   #11
Rewards Points: 766
I picked up a hole saw kit at one of those truck tool sales, for about $12.00, it has sizes from 1.5 inch up to 4.5 inch, just need to change the cup on the arbor to go bigger . that would work great for you. Then chisel out the concentric rings. And use something a bit less rust prone than a tuna can. Even a small Tupperware bowl would last much longer.
ED
de-nagorg is offline   Reply With Quote
Old 03-17-2014, 05:39 PM   #12
Rewards Points: 1,062
Question
Just out of curiosity, why do you need to do that ?
Old 03-17-2014, 07:05 PM   #13
Rewards Points: 86
Read the next sentence.
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
drilling hole in sink wazeaz Plumbing 4 03-18-2008 02:38 AM
Filling a huge stump hole moneymgmt Landscaping & Lawn Care 2 11-28-2007 01:34 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
