Drilling Floor Joist - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-10-2014, 06:02 PM   #1
Question
Drilling Floor joist
What is the code for the size of hole drilled thru two overlapped joists directly above a support wall? I have two 2x8 joist overlapping directly above the support wall below, and I need to drill a 3-1/2" hole to move the drain line from a toilet from one joist space over to the next joist space (I can't go below the joists either). Can this be done, or is it against code?
weekendhandyman is offline   Reply With Quote
Old 02-10-2014, 06:55 PM   #2
Rewards Points: 1,954
That would be a great question for framers (carpenters)
Ghostmaker is online now   Reply With Quote
Old 02-10-2014, 06:59 PM   #3
Civil Engineer
Rewards Points: 4,780
We don't know what code you are under, since you failed to post location. Best is to check with your local building inspector.
Old 02-10-2014, 07:00 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 678
No, you can't drill above a bearing point.
To get more info, I'm moving your post to a different board.
BTW- welcome to DIY Chatroom
Old 02-10-2014, 10:11 PM   #5
Registered User
Rewards Points: 5,516
Maximum; 1/3 depth of joist-- leaving 2" of solid wood above and below the hole; http://publicecodes.cyberregs.com/ic...9_5_par030.htm
http://publicecodes.cyberregs.com/ic...?bu2=undefined
Check locally with AHJ, though a State code would follow one or both the "I" codes stated.
Gary
Am I drilling into plaster and lathe? jespisa Drywall & Plaster 3 07-15-2012 08:01 PM
Drilling holes in concrete slab spaceman spif Building & Construction 12 10-18-2010 09:10 PM
Drilling asbestos siding (hanging shutters) MichaelDutch Remodeling 3 06-15-2010 10:49 AM
Help: Drilling into concrete or stud? rev1976 Building & Construction 7 05-11-2010 01:47 PM
Granite countertop drilling options dantm General DIY Discussions 1 02-09-2010 12:42 PM
