Drilled Through Ceiling Joist - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 11:43 PM   #1
drilled through ceiling joist
Hello, I was running wire from my attic, down through the exterior wall of a bedroom, and into my garage under the bedroom. I was drilling up through the top plate in the garage and ended up drilling through a ceiling joist with a 5/8 spade bit. It was at a bit of an angle towards the outside of the house. I'm concerned the structural integrity is compromised. any advice would be appreciated.
joe1024 is offline   Reply With Quote
Old 04-10-2013, 12:09 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,286
What size are the joists and where in the joist did you drill through it?
It is probably fine in all likelihood.
Old 04-10-2013, 12:39 AM   #3
thanks for the response, the joists are 2x7. I basically drilled straight up into it at an angle aimed toward the outside of the house. I would guess when I hit the joist it was about 1" from the inner edge of the plate. I probably went at least half way through it and started to hit siding.
Old 04-10-2013, 07:41 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
does the joist sit on top of the wall?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-10-2013, 07:54 AM   #5
Roofmaster
Rewards Points: 2,172
Don't worry about it.
Old 04-10-2013, 11:45 PM   #6
Registered User
Rewards Points: 5,498
"R802.6 Bearing. The ends of each rafter or ceiling joist shall have not less than 11/2 inches (38 mm) of bearing on wood or metal and not less than 3 inches (76 mm) on masonry or concrete." from; http://publicecodes.cyberregs.com/ic...par027.htmGary
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 09:34 AM
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 12:21 AM
Bad news - asbestos and a failing ceiling joist system sheslostcontrol General DIY Discussions 17 05-30-2011 11:34 AM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Ceiling Joist Worries clayrabbit Building & Construction 11 01-06-2008 05:07 PM
