-   -   drilled through ceiling joist (http://www.diychatroom.com/f14/drilled-through-ceiling-joist-176721/)
joe1024 04-09-2013 11:43 PM
Hello, I was running wire from my attic, down through the exterior wall of a bedroom, and into my garage under the bedroom. I was drilling up through the top plate in the garage and ended up drilling through a ceiling joist with a 5/8 spade bit. It was at a bit of an angle towards the outside of the house. I'm concerned the structural integrity is compromised. any advice would be appreciated.
Windows on Wash 04-10-2013 12:09 AM
What size are the joists and where in the joist did you drill through it?
It is probably fine in all likelihood.
joe1024 04-10-2013 12:39 AM
thanks for the response, the joists are 2x7. I basically drilled straight up into it at an angle aimed toward the outside of the house. I would guess when I hit the joist it was about 1" from the inner edge of the plate. I probably went at least half way through it and started to hit siding.
GBrackins 04-10-2013 07:41 AM
does the joist sit on top of the wall?
jagans 04-10-2013 07:54 AM
Don't worry about it.
Gary in WA 04-10-2013 11:45 PM
"R802.6 Bearing. The ends of each rafter or ceiling joist shall have not less than 11/2 inches (38 mm) of bearing on wood or metal and not less than 3 inches (76 mm) on masonry or concrete." from; http://publicecodes.cyberregs.com/ic...par027.htmGary
