Dressing Up A Deck - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-04-2009, 01:29 PM   #1
dressing up a deck
I am building a deck and ordered some decorative round colulms. I want to dress up the beam. What kind of product can I use to span 19' to be supported by the coululms?
Thx
charlesual is offline   Reply With Quote
Old 10-04-2009, 02:30 PM   #2
Old School
Willie T's Avatar
How many ways can a cake be decorated? Same idea. How much money do you intend to spend? Routering, carving, molding, foam overlays, etc.
Willie T
Old 10-04-2009, 04:16 PM   #3
Rewards Points: 5,336
Thx
The unsupported span of 19' is too far a distance. You need to modify the plan.
Ron
Old 10-04-2009, 04:35 PM   #4
You would need to consult with an engineer
19' is beyond the span distance for normal wood
Are the columns for the posts to support the deck?
Or to support a roof or pergola?
You would be better of cutting that distance in 1/2
Old 10-04-2009, 05:30 PM   #5
I'm good on ithe post spacing
There are 4 posts supporting the 19'. I was planning on using 2 2X12 for the beam but was thinking I might be able to use something better looking then 2X12. Do people wrap these or buy a beam that already has a decoative look?
Thx
Old 10-05-2009, 07:46 AM   #6
Not so new
12penny's Avatar
Rewards Points: 520
charles...build your beam of whatever is required in your area. 2x10's would probably be okay, but check with your building dept. When they come to inspect, you dont want to have to take it apart and fix it. Then use 1x12x16' pre-primed trim boards to wrap the beam. A PVC product or leftover decking are also good choices.
12penny is offline   Reply With Quote
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 06:57 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 07:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
