Dream Garage, Possible? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-12-2007, 02:25 PM   #1
Handyman/ Snow Removal
Hello,
I've been thinking about haveing a garage built. 2 1/2 wide, but also have a basement in the bottom, drive onto a lift in one of the ports, and either stay parked there, or be able to push a button and go into a basement section of the garage. More for storing bigger equipment. I'm not sure if it's possible though, and if it is, how much it would cost?
Thank you.
McGaw is offline   Reply With Quote
Old 12-12-2007, 02:37 PM   #2
Eibwen
Probably cost a bazillion with a basement under a garage due to the support needed.
Consider an old time grease pit if its working on the bottom side of the car that your gettin at. That way you can drive over it and then walk down into the pit.
Thats why they always say..... Buy the biggest garage ya can that has a house attached to it!
Sammy is offline   Reply With Quote
Old 12-12-2007, 02:41 PM   #3
I wouldn't be working on any vehicles, as I'm useless when it comes to that sort of stuff. I would just want it like a 2 1/2 wide on the top, and a 2 wide on the bottom so in the winter I could store the trailer and atvs, etc.
Old 12-12-2007, 03:29 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,370
Nope,....... It can't work that way,....... The platform would either be up, or down,..... If down, there's no floor to park on above..........
But,..........
If you build Higher,......
You can install Lifts,+ raise a vehicle,+ then park Under it.........
Bondo is online now   Reply With Quote
Old 12-12-2007, 03:41 PM   #5
Bondo, I wouldn't be leaving the lift in the basement, it would only be used to get heavy things like a trailer down there, and then it would be raised to park on it again. It wouldn't be left down.
Old 12-12-2007, 04:54 PM   #6
How ya gonna get the trailer off it so you can raise the lift again?
NateHanson is offline   Reply With Quote
Old 12-12-2007, 04:59 PM   #7
That was another prolem I had thought of, but I think I've come up with an idea, either get a lift with a removeable side, or weld myself some hinges or something to the lift and make it removeable.
Old 12-12-2007, 05:01 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Ever hear of one house that has rotating floor pads in the garage? You pull in and onto a rotating pad(s), and press a button and the pad turns your car around for you. You should include that in the design.
- Build Well -
Old 12-12-2007, 05:04 PM   #9
lol, It's gotta get build first, but that's certainatley an option to keep in mind I'm still looking for someone to tell me some prices, and if it's at all possible.
Old 12-12-2007, 06:39 PM   #10
Mod / ArchiBuilder
Cole's Avatar
Hello,
Thank you.
Check out Jerry Seinfield's setup!
Its Sweet!!!!!!
http://www.thesmokinggun.com/archive/0527041jerry1.html
Cole is offline   Reply With Quote
Old 12-13-2007, 06:19 AM   #11
Bondo's Avatar
In that case,... You'll need atleast Double the floor space in the cellar,....
Just to have storage,+ maneuvering space....
Because All of the footage where the lifts are will be Unusable.......
Is there any grade change at the site,.......
It would make more sense to have doors at the lower level,.....
In essense, a garage over a garage, each with it's own access.......
Old 12-13-2007, 02:10 PM   #12
I'm not to sure what you mean... Like have a two story garage, no basement? Plus I'm still looking for some prices.
Old 12-13-2007, 05:35 PM   #13
Rewards Points: 5,336
It is not possible using the parameters stated. No one will give you an estimate. They might say they will come, but no one will knock at your door.
Ron
Old 12-14-2007, 05:31 AM   #14
Google spancrete and find local installers to give you a quote. I've done two remodels with this and its very exspensive. I would imagine engineering for that big of a cutout would only increase the cost though.
pavola is offline   Reply With Quote
Old 12-14-2007, 07:20 AM   #15
Bondo's Avatar
Are you building on a Side Hill,..??..??
Is it possible to build it as a 2 story as in,.....
Level 1 being the Basement,+ level 2 being the traditional Garage, as viewed from the House/ street level,...........
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 08:41 AM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 11:09 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 10:38 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
