Drafty Cupboards - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 08:36 AM   #1
Drafty cupboards
Forgive me if this is not the right forum category. Now that winter is here, I am acutely aware that my kitchen cupboards are drafty. I know, this sounds strange -- but when I open them, it is not just that they are quite a bit cooler than the ambient temp of the rest of the room, but I can feel the air moving when I stand near the closed cabinets. Why? Is this caused by the through holes for the pipes? Minimal insulation behind them? It doesn't seem energy savvy to have a howling draft behind my 1" thick cupboard doors. What is the solution?
Felmo is offline   Reply With Quote
Old 12-21-2011, 09:49 AM   #2
dannyoung85's Avatar
My cabinets are the same way. I just assumed it was because they are installed on an exterior wall.
dannyoung85 is offline   Reply With Quote
Old 12-21-2011, 10:10 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I assume you are talking about the lower cabinets?
Any cabinets on an outside wall will be cooler inside the cabinets if the walls aren't properly insulated. My guess the entire house is like this but the cabinets trap the cooler air and make it more noticeable.
The bigger issue is usually any holes in the walls that are there for the plumbing improvements if the plumbing penetrates the walls. May be a freeze risk there if that is the case. Take a look and see where the air could be coming from. The drafting may simply be convection.
XXX
Old 12-21-2011, 11:55 AM   #4
drafty cupboards
Thanks for your input! I am going to investigate and see what I can find... That would be a total drag if the entire house suffers from poor insulation.
Tile first or cupboards first??? ingeborgdot Flooring 8 04-22-2010 03:48 PM
80's Cupboards with Oak Trim bubba62 Remodeling 4 10-26-2009 04:20 PM
rustic looking cupboards solomon8 Painting 1 09-19-2009 01:34 AM
Drafty House - adding tyvec to a nine year old vinyl sided house? songbird_63366 General DIY Discussions 8 02-10-2009 05:21 PM
KITCHEN CUPBOARDS!! in a mess! ashleyc General DIY Discussions 1 07-02-2006 12:55 PM
