Double Prehung Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 10:28 AM   #1
I have been looking everywhere and can't find 18" double doors (pre-hung) to fit in a 36" opening. I have looked everywhere. These doors are going to go into a closet and will open and close with a top ball catch.
Is this really that hard to find?? Is this something I'm going to have to custom make? I'm even getting to the point where I figure I can get (2) 18" pre-hung doors and rip off the verticals.
Oswald is offline   Reply With Quote
Old 08-10-2009, 10:52 AM   #2
Are you stuck on a double or will a bi-fold work?
jerryh3 is offline   Reply With Quote
Old 08-10-2009, 12:07 PM   #3
The wife is stuck on a double. I wouldn't mind a bi-fold .. but you know how that goes ...
Old 08-10-2009, 03:23 PM   #4
Drywall contractor
Rewards Points: 1,070
Yeah, if mama's not happy, nobody's happy. You'll have to special order or find a millworks in your area that can make them on-site. The smallest double/prehung the big box stores carry is usually 60". (Might find a 48".) Your least expensive (and likely fastest turnaround) route would be through a millworks or even a regular lumber yard. HD and Lowes are normally 10 working days and quite a bit more expensive (since they order through a millworks and tack on their "handling fee). Here locally there's a lumber yard that has a door and window shop that custom builds units quite reasonably and turnaround is often a few days instead of weeks......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-10-2009, 05:00 PM   #5
Thanks for the tip! I'll hit the yellow pages and start calling around.
Old 08-10-2009, 06:14 PM   #6
Drywall contractor
Good luck. There may be an old "family owned" lumber yard (like the one I'm referring to) that's been around for years and can at least point you in the right direction. You may even drive by it on occasion, but don't give it a thought because you figure it's just for contractors. Most folks are just "conditioned" to dealing with the big box stores.....
Old 08-10-2009, 06:37 PM   #7
I'd much rather give my business to a smaller ma' and pop type shop.
Old 08-10-2009, 06:43 PM   #8
Custom Cabinet Maker
I got mine from local lumberyard, Just had em ordered, with the bullet catches already installed. Got em made in Birch.
skymaster is offline   Reply With Quote
sliding screen double patio doors bcrest General DIY Discussions 1 10-22-2008 07:04 AM
Double glazed doors Big Al Building & Construction 6 04-19-2008 06:09 PM
Cutting prehung doors narrower? perpetual98 Building & Construction 2 04-14-2008 10:43 PM
How much clearance do I need between double french doors? SnowDrops Carpentry 12 11-29-2007 08:54 AM
