Double Folding Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 06:32 PM   #1
double folding doors
i have an entry into a little used dining room. i want to install 4 doors/panels in which the doors (2 on each side) will fold onto each other then both onto existing vacant wall space on each side of the entry way.
my thinking is like shutter hinging.
help!
remodeling lady is offline   Reply With Quote
Old 02-20-2010, 08:44 PM   #2
Rewards Points: 5,336
Sounds like a bifold door. But without details of the opening size, it's hard to give advice.
Ron
Old 02-20-2010, 09:17 PM   #3
DIY staff
Rewards Points: 7,174
It can be done. You will need to install jambs and casing on the opening.
High quality bi-fold doors could be used--they would have to be hinged to the new jambs like conventional doors,stop molding applied to the jambs.
a double set of ball catches should hold them secure when closed.
This all may sound like gibberish to you if you aren't familiar to the terminology.
In layman's terms--Yes you can do this.----Mike---
Old 03-04-2010, 09:53 AM   #4
Have you thought about a double pocket door?
stevesandsons is offline   Reply With Quote
Old 03-04-2010, 10:08 AM   #5
Installing doors that way is like taking the pins loose in the middle of a set of bi-folds. They just dangle there in the dang way. I have done this kind of install but the outer door liked to "open" into the room. The solution was a decent magnetic catch (carefully hidden) to keep the dang things together when in the open position. They worked but were kind cumbersome. Have you concidered some nice drapes?LOL
mr makita is offline   Reply With Quote
How to get double front doors to close tight Advising Elf Windows and Doors 31 12-30-2012 11:09 AM
Sealing Entry Double Doors SPS-1 General DIY Discussions 1 10-12-2009 05:46 AM
Double Prehung Doors Oswald Carpentry 7 08-10-2009 06:43 PM
Double glazed doors Big Al Building & Construction 6 04-19-2008 06:09 PM
How much clearance do I need between double french doors? SnowDrops Carpentry 12 11-29-2007 08:54 AM
